Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Will not start up!
I have an HP ZV5000. Never had any problems before. Pushed the power button, the hard drive spins for two seconds and the fan kicks on, then shuts off. As a result the screen does not even flicker. I have extremely important data saved on the hard drive and would like to retrieve it. Have any suggestions?
Hello Clintmolly!,
I suggest that since your screen doesn't "light up", you 1.) Determine the exact model of hard drive the unit uses, you can get that information online at the HP website or by physically removing the access panel from the underside of the laptop.  Once you've gotten that information I suggest that you locate another unit of similar size and purchase it.  ( I purchased a Drive replacement doubling the original size for about $60.00, I have a zv6000 ).
2.) For 39.00 investment you can purchase from Apricorn, http://www.apricorn.com, a USB interface that will allow you to connect the existing drive to the system.  After installing the replacement drive you acquired from step 1. ibid.  I suggest installing a new OS to the newly installed drive after installing and properly BOOTing the system you will be able to access your files by way of the Interface from Apricorn.
Actually once the existing Hard Drive has been removed you can use any computer with the Apricorn interface to access your files. Assuming that you don't care about the "Sick System."
THIS METHOD WORKS - PERIOD.
BTW if you don't have an OS to load you can use any freely available one such as LINUX.  You will have to learn a few commands but your files will be accessible.  The assumption here is that the original Hard Drive is properly functional, i.e. some other hardware failure has occured that has forestalled the system from properly BOOTing and that the original system's Hard Drive is otherwise functional.
Good Luck!,
Cheers,
Mr._Synapse
Posted on Feb 15, 2009
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Hi my HP Pavillion ZV5000 fan runs loudly after a period of time and then shuts off. Probably due to over heating.i also already have cleaned the fans. Is there any solutions?
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Apr 02, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hi, hp pavillion zx5000 will not power on. The power source is good. I have tried it with & without the battery. I tried no batt & ac and holding down the on button for 30secs; holding down the on...
I would try the following steps, then contact HP (if these don't work, chances are it's hardware related).
1) Remove the battery and power cable. 2) Hold down the power button for 3 seconds. 3) Reattach the power cable and battery. 4) Try to boot again.
Mar 01, 2011 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
COMPAQ PRESARIO S5200NX WON'T START - Press start button, led's light up for about 5 seconds - hard drive starts to spin, then led's go off and every thing shuts down. Power supply is ok (swapped power...
Hi:
Since you swapped the power supply already, and have disconnected the DVD, CD, and floppy, that leaves the hard drive and motherboard!
Look the motherboard over, and see if there are any capacitors that are bulging or leaking out on the tops.
Is the inside of the computer very dusty? Check and make sure when you power up the tower, that the cpu fan is spinning up.
Your CPU could be overheating, so removing the Heatsink fan and re applying thermal paste is an option too
If it is, try resetting the CMOS on the motherboard, or pulling the CMOS battery for a minite.
Do you get anything to display on the screen?
If you have more than one stick of memory, take out one of the sticks if possibleif possible.
Nov 06, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
My hpzx5078cl laptop will not boot after i had put in a new dc jack, the battery charges fine, but the laptop, just comes on and it will not boot at all, the fan just spins up turn off and then spins...
Check the Leds on laptop. Try to turn on the laptop with just the a/c adapter. Disconnect battery,a/c adapter and drain flea power by holding power button for 15 second. Connect /ac adapter and check. Disconnect harddrive and memory from laptop.Reconnect and try to reboot.Possible issue with motherboard.
Aug 18, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion zv6000 won't power up after getting zapped
It sounds like you have a piece of junk, the hard drive mighr be OK , if it is you can put it into a USB hard drive adapter case and use it as an external USB hard drive.
May 05, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
I think your motherboard has gone bad, even though you hear a fan working, its just on a hot wire on the motherboard.
Dec 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
219 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
