Question about Gateway Computers & Internet
Delay in Monitor display once the system goes in sleep mode
I purchased a new Gateway Model: LX6810-01 Desktop.
Sytem work fine except when it goes in sleep mode. It takes 2-10min for the monitor to display.
I set the sleep mode and motior power off. It works fine but again if I manually switch off the monitor and turn it on the delay in display persists.
  • 2 more comments
  • akyogi Feb 06, 2009
    Thank you for the solutuion... Is this common in new desktop's?
    I am planning to return it since its just hardly 2 weeks since the purchase date.
  • akyogi Feb 07, 2009
    Thanks a lot
  • Anonymous Mar 16, 2014
    It won't turn on other than flashing monitor is going to sleep
  • Anonymous Mar 17, 2014
    The P/C monitor Goes directly to sleep mode and states that there is no signal coming from the P/C.
    President:
  • 2,976 Answers
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Posted on Feb 06, 2009
  • David Shaub Feb 06, 2009
    New computers, both desktops and laptops have so much junk running in the background, it's surprising that they ever get fully booted up. Go to start, run, type in "msconfig" without the quotes. Go to the startup tab and IF you know for sure what something is, and you don't need to have it running ALL OF THE TIME, uncheck it. When you reboot, the unchecked items won't start and bootup will be faster. If you're unsure about something, leave it alone until you can identify it.
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
My gateway dx4300-03 starts up fine and then about 5 minutes into working the monitor goes blank and the computer seems to go into sleep mode and won't restart until I unplug from the back and re plug in. ...
By Cyclontech!
Hi, The solution to fix the problem is by changing your power supply. Just make sure that you replace it with a 500W or higher and not with the same 300W which does not have enough power for this system, plus it is defective. I have changed the power supply to 4 diferent gateway PCs same model dx4300. And all 4 are working perfect. And run a check disk on CMD to fix the disk errors that were created every time you unplugged it and turned it on again.
Oct 28, 2010 | Gateway DX4300-03 Desktop PC
Does samsung monitor save power in sleep mode?Or will it just displays black all over the monitor?
yes, all monitors work directly with the cpu, the cpu sends message to the monitor, so if the system is in sleep mode, automatically the monitor stops work excepts the cpu comes up again then the monitor wakes, in a nutshell, a monitor is connected to power while in sleep mode but has no signal to function
Jul 16, 2009 | Smart Modular SV3170A
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Mar 18, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
487 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
