Question about Sony Ericsson K750
Hi, my phone wont switch on properly, it just lights up with a wh
My mobile is motorola l9.i can not connect with net through teashark in my mobile.
Posted on Feb 06, 2009
  • maulik56 Feb 06, 2009
    my mobile is motorola l9.i can not connect with net through teashark in my mobile.
  • 170 Answers
This problem occurs because of not ejecting the device properly when connected to pc(computer) via usb cable.
solution:connect your phone to computer via usb at the system tray you see a icon . right click on the icon.the device name appears on the new tab click on it.the hardware is ejected & remove the usb cable
I have a el/gas water heater with ign. switch in cabin switch does not come on when WH does not ignite also the cabin heater doesn't ignite either, are both ign. units normally on same circuit ?
I would start with the thermocoupler that is or usually located behind a removable panel on the WH and check the other items for one also.
Dec 04, 2015 | Cars & Trucks
Tail light wiring color code 2005 dodge cgrand caravan
Sounds like you have the wrong part.Did you buy it new or is it used?
Aug 02, 2015 | 2005 Dodge Caravan
I am trying to install two Lutron dimmers in the same box. The dimmers are models MA-S8AM-WH and MA-600WH. I can get get the MA-600-WH to work but not the MA-S8AM-WH. Anyone have any hints.
My first thought is that if you were using these devices to replace existing light switches, the MA-S8AM has an additional electrical connection that wasn't necessary with a light switch or the MA-600. The MA-S8AM has an addtional screw on it (I think its silver in color) that connects to the neutral wire in the circuit. Hopefully you have a bunch of white wires all wire-nutted together in the back of the box - pull a connection from there and attach.
If that's not the issue, then I would call Lutron's tech support. They're available 24/7, so you may as well. They're at 1-800-523-9466.
Aug 25, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
There is sme problem wh ma laptop wen i am
If the screen shows a picture but very faintly, the inverter is either not connected properly or faulty.
If there's nothing on the screen at all
1) Your screen is either not connected properly or faulty.
or 2) *********** board has a fault.
or 3) Your graphics card/chip has a fault.
You can connect your laptop to another screen using the VGA port on the back. You have to switch to the spare screen using the keyboard, usually Fn and another key. If the spare screen then shows a picture, *********** board and graphics card are OK, your screen is at fault or not connected properly.
Checking the connections to both the inverter and screen will require dismantling you laptop. If you go about this, ensure all power, including the battery is disconnected.
Apr 26, 2010 | HP Compaq Presario V2000 Notebook
I just wired 2 3way switches with 3 lights in between them. Tried 2 different dimmer switches on the circuit but neither would dim the lights nor operate the lights as they should. The lights perform...
In general practice, you can only install ONE 3-way dimmer switch to control the lights. If you use two regular 3-way dimmer switches, the circuit won't work.
However, newer technology allows for double 3-way dimming from different locations. See this article about how to do this:
http://www.smarthome.com/2494M3/SwitchLinc-3-Way-Dimmer-INSTEON-3-Way-Dimmer-Kit/p.aspx
Mar 12, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
04 Envoy xuv 4 wh. drv. stays in 4 wh drv. HI
Try putting your transmission in neutral and slowly shifting the 4wd selector to each position but you have to wait a few seconds between selsctions as it has to go through your vehicles computer, shifting to fast will cause your symptoms. I hope this helped you out. Roger
Feb 08, 2010 | 2004 GMC Canyon
Interior dome lights wont activate wh en doors
If none of the interior door lights work, check the fuse, and check the bulb. If they are both ok, then you may have a bad relay or switch but you will have to trace the wiring which is a pain.
Sep 16, 2009 | 1996 Cadillac DeVille
Wireing ot lights
Yes, you will need to provide a 120 volt outlet. You should be able to download the manual from:
http://www.heath-zenith.com/
Jan 20, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Sony Ericsson K750 Logo
89 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
