Question about Panasonic SA-HE100 Receiver
DVD with RCAs, TV with Scart. Have an adaptor but no joy. Why?
It's a new Phillips DVD player and an old Goldstar TV. The DVD has Y,R,W plugs and the back of the Scart adapter is G,R,B. I've tried plugging it in various diff ways to check but think I"ve got it right; Y=G, R=R, B=W?  But I still can't tune my TV into it. I don't have remote for the TV so am hunting through the channels trying to find the DVD signal.
My problem is, I don't know if it's not working because the TV needs to be on an AV channel I can't reach without a remote (although I have had this TV tuned to a VCR before) or if it is because I've got the plug round the wrong way. Help!
  • lizzylomax Feb 07, 2009
    Erm... thanks but there is no yellow at the other end. That's the problem; I'm working with colours that do not match. I have rca out of the DVD, pls a few other sockets i haven;t really looked at, and the TV ONLY has a scart socket, which I've now plugged a GRB adapter into.
    Do I need to use different output points from the DVD perhaps?
    Scholar:
  • 93 Answers
The dvd has Y= video composite, R= Right channel audio, W= Left channel audio these are the common jacks of electronics, Now the G=Green,R=Red,B=Blue are usual Component VIDEO OUT/IN for higher video resolutions, this could explain no video picture, try the Y=Yellow to Y=Yellow from dvd to TV then set tv to a VIDEO input 1 or 2
Posted on Feb 07, 2009
  • Mike Lynch
    Mike Lynch Feb 08, 2009
    You can check to see if the DVD player has component video out 3 rca jacks pB pR pG many DVD player use this video out for higher video resolution, not sure about an older goldstar TV using this video input but newer TV monitors will have this option for input, the vcr would work on a freed-up RF channel like channel 3, but DVD video signal will not work on a channel frequiency, you need to use a video input mode to make the tv a monitor, some tvs will work if you get a 00 channel but many require you acsess the video in selection, check if your dvd and tv have a possible s-video plug, this will be a round din type adaptor with 6 little pins, maybe try out of the dvd player into your vcr and then to the tv, this will work in some setups.
What lead do I need to connect a DVD to Tv with no scart socket Technika 40E21B-FHD
the TV has component input so if you get an AV lead will come with 1 white leade and 1 yellow lead at each end, plug them diectly into TV and then at other end of cable get an AV to scart adaptor for your DVD had to same for my daughters TV and dvd as had no scart
Dec 12, 2014 | Televison & Video
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
How do i hook up my old admiral vcr to my new rca flat screen tv to tape american idol?
Do both have Scart sockets? If they do you can get a scart lead. All you have to do is set the VCR to the AUX setting that the scart is on and press record!
You won't be able to watch another channel though whilst recording. If you are using the scart socket for say DVD (on the TV) you can get one of these:fa1357d.jpg
Feb 21, 2010 | Goldstar GVR-E435 VHS VCR
I need to reset a sony dvp-f21 to give standard
As far as I know, the output of your dvd is standard. If you're not getting a picture, check you have the correct audio and video leads into the correct plugs on both the dvd player and the scart adaptor, then make sure the scart is pushed fully home in the tv.
Also check that you have the correct input selected on your tv. This is done but pressing the button on your remote that has a square or circle with an arrow through it. Keep pressing it until you see your dvd.
Jan 26, 2010 | Sony DVP-F21 DVD Player
I cannot connect the dvd, freeview and tv wires so that they all work. I only have one scart socket at the back of the tv but have bought a scart adaptor to solve this problem. I cannot get my dvd to work...
If your freeview has two scart sockets,connect a scart from the freeview(marked tv)into the tv,then one from the dvd into the other scart socket on the freeview,the main aerial should go into the freeview and a flylead out into the tv.Hope this helps
Sep 11, 2009 | Sony DVP-NS50P DVD Player
Why is my bush tv black and white when i watch a dvd
you are using the svhs scart if it has another scart swap the plug over
Dec 08, 2008 | Televison & Video
Top box conns
your freeview box tv scart goes to the tv /the dvd goes to the aux on freeview and you can connect your vcr to the tv if it has a spare scart socket or the dvd player
Jan 14, 2008 | Computers & Internet
Need help with DVD hookup
What connectors do you have on the back of you television? If it has the 3 red white and yellow ones then you can get an scart adapter and leads to connect it.
Dec 29, 2007 | Televison & Video
Panasonic SA-HE100 Receiver Logo
170 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
