Question about Casio Parts Cash Register PC Desktop
Casio TK-7000: "XZ" lock-up problem
Yesterday when I tried to print an "x" read, the machine instead went into "xz" mode and printed out a Batch 01 that has the accumulated totals of the last few years.
The machine then locked in this mode and would only print this report. Once it was left for 30-45mins, it reverted back to normal operations and could be used again for transactions.
I then tried to do an "x" read today and it has done the same thing.
I have the manual and as far as i can see, there is no mention of an "xy" mode at all.
The machine is the older type and I have been using it for nearly 4yrs and have never seen this problem before.
Thanx mark
Check your report. if you see top of the receipt will print x. z.or z2
if you see z2. it.s nothing wrong. you just made periodic report. le
Posted on Feb 15, 2009
  • 737 Answers
It sounds like you accidentally turned the key to Z2 mode. This is the periodic totaliser, so you have reset it by mistake. The rest of your description makes no sense. I'd say you probably have main board failure in the machine.
Posted on Feb 06, 2009
XE-A207. Won't print while ringing up. But will when transaction over if you push receipt copy. It will print x/z readings
The receipt is turned off.
Turn key to OP/XZ mode. Press receipt button. Turn key back to REG mode.
May 13, 2017 | Retail Supplies
Casio tk-7000 scanning and PLU programming
You can add a Hand held Scannerbar with your Casio Tk -7000
Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register:
1. connection to cash register - unscrew and screw back in.
2. connection to scanner, unplug using paper clip into hole and push back in again.
3. rescan default sheet given whe nyou purchased the machine.
4. clean head of scanner.
5. check for cracks on scanner, ie. loss of vacuum.
For MOre Information visit the following sites:
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Oct 07, 2008 | Casio Parts Cash Register PC Desktop
Pausing between each label print. It never used
Send this to your printer via serial or parallel
May 13, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
When i start tk 7000 cash register i get er004 message
Try this:
Turn key to PROGRAM mode.
Turn power off at wall.
Turn power on at wall.
When you see 'FFFFFFFFFF' on display, let go of RECEIPT FEED.
Now look at the print out and tell me what the big number is right at the bottom.
Dec 25, 2008 | Casio Parts Cash Register PC Desktop
How do I allocate PLUs to departments on my CASIO TK-7000?
take a readout of the department and groups first
205 subtotal
1 cash 30 cash
this will print out your departments
206 subtotal
this will print out your groups
1166 subtotal
enter your 6 digit number then press all the products linked to that department / group
your 6 digit number = DDGG00 DD= Department GG= Group
then 00
so for dept 1 gp 1 = 010100
when finished
press subtotal
Dec 07, 2008 | Casio Parts Cash Register PC Desktop
Casio tk 7000
Hi. It sounds like the guest check memory is full due to too many items in the tables. This is usually caused by people opening tables, filling them up and never finishing the table. The easiest way to overcome this is to reset all tables. Note: This will clear any current sales you have in tables, but should fix the error.
Turn key to X1/Z1 25 CASH CASH If it gives an error, then try 25 CASH 1 CASH It should print an open check/table report and show you which tables were taking up the memory. It will clear the sales out of those tables. Now turn back to REG mode and try it.
Nov 09, 2008 | Casio Parts Cash Register PC Desktop
Not printing the correct text / picture
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Sep 18, 2008 | Zebra Stripe S600 Thermal Label Printer
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Casio Parts Cash Register PC Desktop Logo
117 people viewed this question
Top Casio Retail Supplies Experts
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
