I turned my Nokia 6133 for the night, next day and since, it will not turn on. I tried with my wife's phone (same phone) battery and even with the charger plugged in; and still won't power on.
The battery is good, it powers on my wife's phone. Will a jaff box work even without my phone powering on?The battery is good, it powers on my wife's phone. Will a jaff box work even without my phone powering on?
You can't post conmments that contain an email address.
Confirm the format. When prompted, select "Yes". Wait patiently while the Nokia 6133 formats the memory card.
Enter a name.
When the Nokia 6133 is finished formatting the memory card it will ask
you for a name. Enter a name into the Nokia 6133 for the memory card.
The Nokia 6133 allows the name to be up to eleven characters and
numbers.
Try taking the battery out and plugging it in to see if it powers up for an extended period of time. If it does, the battery needs to be replaced. If it still powers down there is an internal problem with the phone, you could take it in for repair if you have warranty service on it. The repair is likely to cost more than getting a new phone. Most carriers will offer you a discount if you have had your phone for at least 2 years.
I have the same problem two weeks ago. I opened my phone and kept it under the table lamp to dry off some moisture and my screen came back and working good.
Also tried to reset it by taking out Sim card press *3 send button together when turn on the phone ,it will take a while ,but it will reset the phone and will ask for the sim card info.
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
I believe that is the bottom right square on the top field. The red one one that has a small dot next to it. Make sure the battery is charged. If in doubt, turn it on while connected to the charger.
