Question about Kenmore 98702 Stacked Washer/Dryer
My washer will not go to spin cycle,.
Washer goes through cycles,but when it hits spin it stops..leaving machine full of water
  • Anonymous Mar 19, 2009
    water will drain but will not spin and you smell something hot
  • Garth Jackson May 11, 2010
    Is this a top loader or a front loading washing machine?
    Scholar:
  • 99 Answers
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Posted on Feb 06, 2009
KitchenAid Washer Will Not Go Into Spin Cycle
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. You can usually look and visually see the spot where the switch should be and if damaged. How to repair :
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off. The lid switch will be attached to this portion so located it, remove the two screws that hold it in place, under the lid, and swap out with a new one. This is a cheap repair, just take your time and you'll be fine.
Jun 05, 2012 | KitchenAid Washing Machines
Whirlpool Inglis dead
May 11, 2012 | Whirlpool Inglis IP4400 Washer
Washer does not spin cycle, why?
Apr 30, 2012 | Whirlpool Washing Machines
Doesn't spin
Apr 29, 2012 | Kenmore Washing Machines
Will not spin out water
Apr 25, 2012 | Kenmore Washing Machines
Apr 24, 2012 | Kenmore Washing Machines
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore 98702 Stacked Washer/Dryer Logo
138 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
