Question about Bosch 24 in. SHU43 Built-in Dishwasher
Upper Spray Arm in the dishwasher has fallen off
The small Upper Spray Arm (located in the top) of my Kitchenaid dishwasher has fallen off. It appears it's held in place with two push-in fasteners. I have the arm and one fastener. If I purchase a new spray arm (with the fasteners), how do I install it?
Thank you.
Lynda
  • ttkt1986 Mar 07, 2009
    I have an shu4303uc diswasher and the upper arm has fallen off. How does it reconnect? I do not see any broken parts.
  • 63 Answers
If you cannot just twist it so it screws back on a part was broken.
So I suggest you contact the manufacturer about this. Im sure that will be much more helpful!
Posted on Feb 06, 2009
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
My kitchenaid dishwasher the water does not get to the upper rack...and the dishes on the second rack on not clean at all....
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer
Jul 17, 2011 | KitchenAid Dishwashers
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bottom rack cleans fine, top rack doesn't clean at all - can I take apart the top spray arm?
yes, the spray arm can be removed and cleaned out.
Also, clean the 3rd (very top spray area) located attached to the top of the dishwasher. You want to make sure this small (1 inch size) piece can spin freely, so water can rinse the upper rack items.
Feb 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Upper spray arm tower came off
You can find a replacement for the upper spray arm (3rd level). Kitchenaid #8268298. See www.pcappliancerepair.com. Their part number is 8193504. $9.15 plus shipping. Good luck and happy holidays.
Joe
Nov 16, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
444 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
