Question about Cell Phones
Micro sd card
Hi, I incorrectly inserted a micro sd card and now it is stuck.Is there a way to open up the device and removing it? Was trying to figure out where the Micro SD card went (booklet had no picture, just words) and was sliding it into the wrong slot when I seen the actual SD slot and tried to remove it. The card slid all the way in. Need help to try to remove it
  • 35 Answers
Open your sd card then it the lock slide if damage replace ....
Posted on Feb 06, 2009
  • michelle stevens Dec 27, 2011
    how do you get the sd card out of the wii
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
Download pictures to computer
Copy photos from cell phone to computer
Connect the supplied USB cable from your cell phone to the USB port on your computer.
The computer will see the cell phone as an external storage device or an external mass storage device, you can then open the photo folder on your cell phone and copy the photos to your computer. If the photos are stored on a mini or micro SD memory card then - An alternate method is to remove the mini or micro SD memory card from the cell phone and insert it into an USB card reader then connect it to the USB port on your computer. You can then open the photo folder on the micro or micro SD memory card and copy the photo to your computer.
Feb 02, 2013 | Motorola Mobility RAZR V3
Transfer pictures from camera to computer
Connect the supplied USB cable from your cell phone to theUSB port on your computer.
The computer will see the cell phone as an external storage device or anexternal mass storage device, you can then open the photo folder on your cellphone and copy the photos to your computer.If the photos are stored on a mini or micro SD memory cardthen -An alternate method is to remove the mini or micro SD memorycard from the cell phone and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the micro or micro SD memory card and copythe photo to your computer.
Jun 13, 2012 | LG Optimus M
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
How to view pictures off of my micro Sd card on my AX380 model phone
The computer will see the cell phone as an external storage device or anexternal mass storage device, you can then open the photo folder on your cellphone and copy the photo to your computer. If the photos are stored on a mini or micro SD memory cardthen - An alternate method is to remove the mini or micro SD memorycard from the cell phone and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the micro or micro SD memory card and copythe photo to your computer.
Sep 09, 2011 | LG Wave AX380 Cellular Phone
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
Sandisk Micro SD Card 2.0 GB
a device called password resetter
is available in market
please use that for reset ur password
thanx
Feb 25, 2008 | Cell Phones
Micro sd card
look for a rubber cover on the phone and take it off and then unscreew it?
Nov 24, 2007 | T-Mobile Wing™ Smartphone
Cell Phones Logo
180 people viewed this question
Top Cell Phones Experts
William Alequin
honeybun1986
Are you a Cell Phone Expert? Answer questions, earn points and help others
