Question about Sabrent Serial ATA (SATA) 1 External + 2 Internal Port + 1 IDE 133 port RAID PCI Card (SA-IDE88) Storage Controller
How can i boot from my pci to sata adapter? i bought a new hard drive i had to get a pci to sata controller to hook up the hard drive but i cant figure out how to make my computer boot up through the pci card i installed the drivers but there only good for the opperating system but what good is that if i cant boot up??? is it even possible to boot up from one of these cards? need alotta help
    Brigadier General:
  • 5,158 Answers
You should be able to chose that drive in the setup (bios) select it to boot first..
Robert
Posted on Feb 06, 2009
I have western digital external hdd usb 2.0 and i have opened it now i want to connect it as internal hdd, its a sata drive inside when i opened the cover
The specific connection depends on the form factor the hard drive mechanism and the computer in which you want to install it. If it's a 3.5" drive and you want to put it in a laptop, forget it; it won't fit in there.
If you want to put a 3.5" drive in a desktop system, you need a SATA drive power connector from the power supply, a SATA data cable, and a SATA port on the motherboard or an expansion card. (note that you will probably not be able to boot from this drive if it is connected through an expansion card unless your computer's BIOS supports booting from a PCI device). It's also highly desirable to have an empty drive bay in which to to mount the unit.
If the hard drive has a 2.5" form factor (2.5" wide), and it is to go into a laptop, you will need the 2.5" hard drive adapter for your particular laptop (many manufacturers have a special cable or adapter for hard drives, although they should all fit the SATA interface. However, if your laptop is an older model designed for PATA IDE drives, the STAT drive will not be compatible.
To put a 2.5" SATA drive in a desktop computer, you need an adapter kit. This includes a 2.5" - 3.5" drive mounting bracket adapter and a cable adapter connector for 3.5" drive connections as described in the second paragraph above. Many computer parts merchants carry these.
Sep 21, 2014 | Computers & Internet
RUNNING A SATA HDD ON AN IDE ONLY MOTHERBOARD
If I am not completely mistaken you have to reinstall the OS on the SATA drive on IDE. That is because the first installation was configured for connection on a SATA /PCI then now on the SATA/IDE port converter.
Sep 25, 2008 | Adapters.com Serial ATA IDE Converter and...
How to install sata hdd for mother board asrock m266a
The drive installs physically like any any hard drive. The problem is that this motherboard does not support the SATA protocol. You would need to get an expansion PCI card SATA controller. Even then, since the motherboard BIOS is not set up for SATA, you would not be able to use the SATA drive(s) as the boot device. Also, you would need a Molex to SATA power adapter for your power supply since the SATA power connector is different. And you would need a SATA data cable if the expansion card does not come with one.
Apr 26, 2014 | Asrock M266A Motherboard
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
Can I install this product in an older XP computer? If yes, How?
If the computer does not have a SATA controller on the motherboard, then you need to purchase a PCI SATA controller and insert it into the PCI expansion slot. You will also need a SATA data cable and a SATA power adapter that converts a 4 wire power connector to a SATA power connector.
Sep 14, 2010 | Western Digital Caviar SE WD1600AAJS 160...
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
Sata drive not recognized at boot up
I HAVE UPLOADED THE MANUAL HERE, IF YOU DON'T WANT TO WAIT THEN GET INTO YOUR BIOS BY DOING A HARD BOOT AND HITTING THE DELETE BUTTON ON START-UP.IF THE MOTHERBOARD SUPPORTS SATA , TO WHICH I FOUND NO CONFIRMATION , YOU CAN CHANGE IT BY GOING INTO THE ADVANCED SETUP PAGE AND CHANGE THE FIRST BOOT DEVICE TO SATA RATHER THAN IDE. YOU WILL ALSO WANT TO CHECK THE PCI SETTINGS AS WELL FOR YOUR CONTRLOLLER CARD ....GOOD LUCK
Jun 02, 2009 | PC Chips M825G Motherboard
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Sabrent Serial ATA (SATA) 1 External + 2 Internal Port + 1 IDE 133 port RAID PCI Card (SA-IDE88) Storage Controller Logo
834 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
