Question about Garmin nuvi 350 GPS Receiver
Screen with message.. " No detailed maps found that support routi
After the Garmin turns on, a screen appears that says " No detailed maps found that support routing. The nuvi cannot be used without them." Directions are spoken but to no desired destination and you cannot view the map because of the screen that has the message above.
  • Garmin Master
  • 2,130 Answers
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Posted on Jul 17, 2009
Garmin nuvi
This is an indication that the map or map unlock key is either missing or corrupted. If you have registered your unit with Garmin, try connecting to your PC and try downloading the map again. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Sep 30, 2013 | Garmin nuvi 200 Car GPS Receiver
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My Garmin will not bring up eny maps . It just brings up no detailed maps found that support routing.
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To register
· Connect the satnav to your computer.
· Go to www.garmin.com and select your country
· Click on “myGarmin”
· Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
  3. Select Details
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 16, 2010 | Garmin nuvi 350 GPS Receiver
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
  2. Select myMaps
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
225 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
