Question about Iomega Silver USB 2.0 Hard Drive
All data has "disappeared" from my 300G usb 2.0 drive.
This is what I get when I try to run the Mac Disk utility:
Verify and Repair disk "Iomega HDD"
fsck_msdos(361) malloc: *** vm_allocate(size=1069056) failed (error code=3)
fsck_msdos(361) malloc: *** error: can't allocate region
fsck_msdos(361) malloc: *** set a breakpoint in szone_error to debug
** /dev/disk1s1
** Phase 1 - Read FAT
** Phase 2 - Check Cluster Chains
** Phase 3 - Checking Directories
No space for directory (Cannot allocate memory)
Error: The underlying task reported failure on exit
1 non HFS volume checked
1 volume could not be repaired because of an error
    Scholar:
  • 180 Answers
You can use a software called g parted , you have to make a dos bootable , and then mount volumes to make the drive ready.
gparted will help you... try the trial version .if you dont susceed let me know.
Posted on Feb 08, 2009
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Tip
How to repair memory card
  1. Download and install a data recovery program. The first thing you want to do when you encounter a memory card error is to attempt to recover important files. There are a number of programs available to accomplish this. Photo Rec is a powerful, free option for most operating systems, but lacks a graphical user interface, which can be intimidating for less advanced users. Find the data recovery program you are most comfortable with in terms of price and features.
    Insert the memory card into your computer's memory card reader. Use a USB card reader or connect your device to your computer via USB if your computer does not have a card reader.
    • Some devices require that you enable disk use via USB through its settings before your computer will recognize it.
  3. 3
    Run your data recovery program. Follow the procedure to recover files for your data recovery program and recover what you can from your damaged memory card.
  • 2
    Go to Computer. Open the Start menu and click Computer. Type Computer into the search box if you cannot find it.
    • In Windows 8, Computer is called This PC, and can be found by searching forComputer from the Start screen.
  • 3
    Find your memory card. Your memory card will be listed under Devices with Removable Storage (Devices and drives in Windows 8). It should be named something like "Removable Disk (M:)". Make note of the drive letter, as it will be needed later.
    • If you cannot tell which disk is your memory card, remove your card with this window open and note the drive that disappears. Remember to reinsert you card before continuing.
  • 4
    Open Command Prompt. From your desktop, press ? Win+R to open the Run dialog. Enter cmd and click OK.
  • 5
    Run Check Disk fix and recover. On Command Prompt, type chkdsk m: /r, where m: is the drive letter of your memory card, then press ? Enter to begin.
    • Depending on the errors found during this process, Check Disk may ask for your input in regards to what action it can take. When this occurs, answer "Yes" and press enter to continue.
    Part 3 of 3: Repairing a Memory Card on Mac
    1. 1
    2. 2
      Run Disk Utility on your Mac. Disk Utility is a Mac operating system utility that can perform disk-related tasks. Select Go from your Finder menu and select Utilities or press ? Shift+? Command+U from the Finder to open your Utilities folder. Open Disk Utility from your Utilities folder.
    3. 3
      Select your memory card. Find your memory card on the list of connected drives. If you do not know which drive is your memory card, remove it and reinsert it to determine which drive it is.
    4. 4
      Repair your memory card. In the First Aid tab, check the "Show details" box, then click Repair Disk. If Disk Utility reports any errors, repeat the repair process until it finishes and reports "The volume appears to be OK".
    on Aug 24, 2015 | Philips SAC2530 - CD/DVD repair kit...
    Hi there. I have a 500gb Iomega Prestige external HDD. I was in my external HDD files, moving some photos from one file to another (nothing I haven't done a million times before). When I moved one...
    you could run the chkdsk utility
    click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
    hope this helps
    Jun 07, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
    I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
    With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
    If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
    Regards, Chris
    May 31, 2011 | Iomega (33090) 250 GB Hard Drive
    When trying to back up files on Mac G4, I encountered a disk reading error. went to initalize, then to verify. error says Verify and Repair disk “disk2s1” ** /dev/disk2s1 Invalid BS_jmpBoot in boot block:...
    You don't say what Mac OS version you're running or many other details, but try running Disk Utility or Disk First Aid, normally in the Utilities folder, and see if it can repair anything.
    It sounds like the drive is failing or has already failed.
    PS: That Mac G4 is well past its prime. :-(
    Oct 11, 2017 | Western Digital My Book Essential 1TB...
    My Mac recognizes the Iomega hard drive, but it will not let me copy or create new folders on it.
    I would run disk utility (found under applications and the utilities) this will give you an indication of the write status and will allow you to verify and repair the disk if necessary
    Oct 21, 2009 | Iomega Computers & Internet
    External hard drive will not mount on my mac
    Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
    Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
    My lacie mounts on the g5 but when i click it, it doesn't open.
    It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
    Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
    Using hard drive on a Mac
    If the drive is empty, use disk utility to reformat the drive as HFS+. DO NOT DO THIS IF YOU HAVE DATA ON THE DRIVE!!! :-)
    Dec 03, 2007 | Seagate 160GB 3.5" External USB Drive 160...
    Iomega Silver USB 2.0 Hard Drive Logo
    277 people viewed this question
    Top Iomega Computers & Internet Experts
    Arora Singh
    Arora Singh
    Starnley Johnwells
    Starnley Johnwells
    Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
