Question about Lexmark X5150 All-In-One InkJet Printer
Please help device device device monitor application occure a error on pc2147467259
    Sergeant:
    Champion:
  • 357 Answers
Reinstall the Drivers for your Operating System
Posted on Feb 06, 2009
Panasonic hdc mdh1
My camera mdh1 Error occurred Problum Solution
Sep 25, 2013 | Panasonic Hdc-mdh1 Hd Camcorder pal Mdh-11...
When printer turned on the yellow lightkeeps blinking and printer will not print
When the yellow light is flashing this indicates that an error has occurred and the printer is not ready to print.
You can open the BJ Monitor application to see what the error might be.
In the System Tray is an icon fixitguynz_0.gif which you can click to open the BJ Monitor
Please let me know if you need any further help.
Regards,
Andy
May 02, 2011 | Canon i 320 InkJet Printer
I've tried for several days to connect to Kodak Easy Share and always get the message: has encountered a problem and needs to close.
Either the software is corrupted or is not compatible with your Operating System.There might be problems with your hardware device also (Kodak Device). First of all when the error occurs we have to find why this error occurred. We have to get more details about it. To do so: We have to examine the Error Logs.
  1. Please click on the Start Menu. Type Run in the search box - in Vista - or click on Run - in Windows XP.
  2. Type this and hit enter key. Eventvwr.msc
  3. Go to the Application Category. Check for errors (Red oval with X on it). If there are errors - see the details - for the Application please post it here. You can read the messages and understand which Application that the error is related with. Check the Date and Time values to verify that it is the exact error related to this software.
  4. Then go to the System category and check for errors related to the System if you have connected the Device to the PC. If exists please let us know.
Solution: e easiest solution is to uninstall the software and re install. Download the recent version from here. Note that Apple Quick time is required by the application. Download it from here. Installation Instructions and Operating System Compatibility - Now compatible with windows 7 as well.
Please rate the answer as well if it helps you to solve the problem.
Thanks for contacting Fixya!
Jul 08, 2010 | Computers & Internet
My Blackberry 7290 won't turn on
Hi, The BlackBerry device is unable to complete the initialization process, the Device Error 365 Restart error occurs To resolve this problem, you need to follow the steps below: Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
Oct 21, 2009 | RIM BlackBerry 7290
Error code 49.4c18
49.XXXXX ERROR
A critical firmware error has occurred.
Turn the device off and then on.
2. Try to determine whether the error
occurs intermittently, while printing, or
when turning on the device.
3. If the error appears while printing,
determine whether it occurs when
printing from a specific computer, a
specific application, or a specific file. If
all other computers, applications, or files
can print without the error, then the
problem may be only within one print job
or computer. Make sure the computer
has the most current printer drivers, or
use a generic printer driver.
4. Go to www.hp.com/support/LJP3005.
Click Download Drivers and
Software. Check for the latest firmware
image version at the bottom of the page.
If this firmware image is newer than the
one installed on the device and the
device can receive a firmware update,
download the newer firmware upgrade.
5. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, contact the software vendor for
assistance.
6. If the message persists, contact
HP Support.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Office Equipment & Supplies
Device monitor application has stopped working
First thing, update Windows. The error occurs from Microsoft .NET Framework. Lexmark could have made their application a bit more compatible with framework, but they didn't.
Sometimes the updates still don't fix the problem. Lexmark has a patch for it on their support site depending on your model of printer.
I also heard rumors in other forums that microsoft has .net framework patches that fix the problem.
Hope this helps.
Apr 12, 2009 | Lexmark Forms Printer 2580 Matrix
Device monitor
Try reinstalling the drivers for your operating system.
Feb 06, 2009 | Lexmark X5150 All-In-One InkJet Printer
Music library Glitch for Upstage
I have noticed that error occuring on other Samsung device. Make sure that you have a memory card in your phone that has a MUSIC folder located on it. You would have to store your music files on the card in that folder. It should recognize your files after that. If not, you could possible have an issue with memory card slot.
Dec 22, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Lexmark X5150 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
