Question about Memorex MVD2042 DVD Player
Need Memorex MVD2045 5-digit remote code
Need 5 digit remote code to program Comcast 3in1 remoteI am having the same problem trying to program the comcast remote to operate my Memorex MVD2045. I tried the codes for the 2042 listed here but they did't work. Any ideas what codes do work for the 2045?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If no codes could be determined, try manually programming the remote:
  • Turn on the Memorex MVD2045.
  • On the remote control, press AUX once.
  • Then press and hold SETUP until the AUX key blinks twice, then release the SETUP key.
  • Using the number pad, enter 9-9-1. The AUX key will blink twice.
  • Aim the remote control at the MVD2045 and slowly alternate between pressing Power and AUX. Stop when the Memorex turns off after pressing the POWER key. This means that a working code has been found. This may take several tries.
  • Press the SETUP key once to lock in the code. The AUX key will blink twice.
Should this not work, then the Comcast remote is not compatible with the Memorex MVD2045.
Good luck and thank you for using FixYa.
Posted on Feb 06, 2009
  • 360 Answers
If you are unable to find the code, you will have to search for the correct code. this is the procedure for the 3 in 1 from comcast.
Searching for a code If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
Example: You've tried all the codes for your DVD, but you still cannot get the remote control to operate your DVD.
  1. Turn on your DVD.
  2. On the remote control, press AUX once.
  3. Then press and hold SETUP until the AUX key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The AUX key will blink twice.
  5. Aim the remote control at the DVD and slowly alternate between pressing Power and AUX. Stop when the DVD turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The AUX key will blink twice.
Checking the Codes If you have set up the remote control using the Searching For Your Code procedure, you may need to find out which four-digit code is operating your equipment. For example, to find out which code is operating your DVD:
  2. On the remote control, press AUX once. Then press and hold Setup until the AUX key blinks twice, then release Setup.
  3. Enter 9- 9- 0. The AUX key will blink twice.
  4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the AUX key blinks (e.g., 3 blinks = 3) and write down the number in the left- most DVD Code number
Note: If a code digit is "0", the selected mode key will not blink.
Repeat step 4 three more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit.
The complete manual for the 3 in 1 can be viewed at this link
A link for the codes for the 3 in 1 is on the manual page.
Thanks for using Fix Ya, please take the time to rate this solution.
Hope this gets your Remote working for ya
clarkco
  • 495 Answers
Try this one:
Memorex 0154, 0250, 0463, 0150, 0178, 0179, 0016
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
Comcast remote code for memorex mlt1912
Logitec should be able to help with this
Apr 02, 2012 | Memorex MLT1912 19 in. LCD TV
Need Universal Remote Code for Memorex tv/dvd/vcr
I work for Memorex tech support. Our number is 800-919-3647.
Unfortunately, Memorex TVs and DVD players can not be controlled by universal or cable remotes. If you need a replacement remote, please call Memorex's parts distributor, Fox International at 800-321-6993 to make the purchase. If they no longer have stock, try www.remotes.com.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jun 25, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
This code worked for me with the Comcast DVR-3 and the Memorex 2042 DVD player: 20831
It may work with the MVD2045 as well.
Jan 17, 2009 | Memorex MVD2042 DVD Player
Need code to program Comcast Universal Remote to our Sony DAV FR9
First you need a Comcast remote with the center button, OK/Select to be grey. Now program in code 1903 to aux. Works on my FR8 System, same basic as FR9. I was unable to get Comcast remote with red center, OK/Select, to work with any codes.
Dec 31, 2008 | Sony DAV-FR9 System
Need memorex mt2274 tv code for comcast multi-control remote
I've had the problem this morning. Memorex codes are 10154, 10463, 10150, 10178, 10016, 10179, 10877, 11570, 11911, &11920. These are for the remote that is for the smaller digital box. I tried them all, and 11570 works for my model - the power shuts off, but the comcast remote will not turn the power back on. Volume works ok.
Jim
Oct 14, 2008 | Memorex MT2274 27" TV
Programming comcast remote
try this...
I got the RCR612 remote to work with my DRC200N by using Memorex code 3318, see if that works, also try 3391 and 3314, I read a lot of people got those to work.
Jul 29, 2008 | RCA DRC200N
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Memorex MVD2042 DVD Player Logo
229 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
