Question about Lexmark X5150 All-In-One InkJet Printer
Device monitor i have a problem a error message pop up on my screen. it said device monitor application has occure stop doing what you are doing #2147467259
    Sergeant:
    Champion:
  • 357 Answers
Try reinstalling the drivers for your operating system.
Posted on Feb 06, 2009
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
Monitor menu is popping up
Issue : screen settings keep coming up and will go away on and off repeatedly
Environment :
Monitor : Compaq FS7600
Computer details : Not provided
Solution :
According to my understanding the the setting message is popping ups as the application is running on the back. It could be software issue within the Windows application.
Have you tried scanning the computer ?
You can also check in the safe mode - if in safe mode computer is running fine then that would be a Application issue with the OS.. Need to scan the system and the update the Anti virus
You can try by restoring the system to the back date - by using the system restore process
To answer this issue i need more details
* Did the software used to work, or has the problem always existed?
* Let us know exactly what you do, step-by-step, and where the process fails.
* When did the problem first begin?
* Does an error message occur? If yes, provide the exact error message and the steps that trigger it.
* Have you done any initial troubleshooting? If yes, provide details about the steps you've taken.
thanks
Tejodhar Atreya
Jan 02, 2010 | HP Compaq FS7600 17" CRT Monitor
My phone has an error that say device error 400 reset. it wont even let me use it or nothing
When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message:
Device error 400
OR
your BlackBerry device resets itself and stops responding.
CAUSE
An unspecified error has occurred with an application on your Blackberry smartphone.
RESOLUTION
NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Jun 11, 2009 | RIM BlackBerry 7290
Device monitor application has stopped working
First thing, update Windows. The error occurs from Microsoft .NET Framework. Lexmark could have made their application a bit more compatible with framework, but they didn't.
Sometimes the updates still don't fix the problem. Lexmark has a patch for it on their support site depending on your model of printer.
I also heard rumors in other forums that microsoft has .net framework patches that fix the problem.
Hope this helps.
Apr 12, 2009 | Lexmark Forms Printer 2580 Matrix
How do you repair the error message IRQL_NOT_LESS_OR_EQUAL for an Evo n410c?
Hi there
This message usually pops up in the "blue screen" This Stop message indicates that a kernel-mode process or driver attempted to access a memory address to which it did not have permission to access.
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 and select "Last Known Good Configuration"
this should repair the machine, although in some case the system has to be recovered
Keep us posted and Merry Christmas
Dec 24, 2008 | Compaq Evo N410C Notebook
Blue screen error 0x00000024 dont have recovery disk
This Stop message, also known as Stop 0x24, indicates that a problem occurred within Ntfs.sys (the driver file that allows the system to read and write to NTFS drives).
Resolving the ProblemDisk Corruption. Corruption in the NTFS file system or bad blocks (sectors) on the hard disk can induce this error. Corrupted SCSI and EIDE drivers can also adversely affect the systems ability to read and write to disk, thus causing the error.
Check Event Viewer for error messages from SCSI and FASTFAT (System Log) or Autochk (Application Log) that might help pinpoint the device or driver that is causing the error. Try disabling any virus scanners, backup programs, or disk defragmenter tools that continually monitor the system. You also need to run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Run Chkdsk /f /r to detect and resolve any file system structural corruption. You must restart the system before the disk scan begins on a system partition. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r.
rate me if you think its fixya...
regards,
Dec 06, 2008 | Gateway MX6025 Notebook Computer...
ERROR IM32FAX.DIL not found/DEVICE MONITOR APPLICATION HAS STOPPED WORKING---LEXMARK X 2500
hi i have a lexmark 3 in 1 and when i turn my computer on this error pops up how do i fix it
Aug 10, 2008 | Office Equipment & Supplies
Lexmark X5150 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
