Question about RCA F36450 36" TV
RCA 36' tube tv won't turn on
I have an RCA 36' tv purchased in '95. Worked fine until I moved it from one room to another - didn't drop it or smash it into any walls but it sure is a bear to move. Now it won't turn on. Disconnected power cord from both the outlet (outlet is good, by the way) and tv and reconnected several times. Every few tries doing that I'll hear 8 or 10 electronic-like clicks as soon as I plug it into the outlet but no luck turning on the set. Any ideas anyone?
  • jsbeardog Mar 16, 2009
    my rca F45036 manf date may 2002 worked fine now wont turn on,
    replaced remote batterys checked power outlet,tried manual
    on button. All it does is manual button light flases a few times than nothing.
  • 39 Answers
Possible that a fuse blew while transferring tv, most like to happen despite care in handling if tv was on for a while, kind of like moving a light bulb that is hot and suddenly filament breaks when you move the bulb slightly. Other than that I'd say it's a good time to get a new tv just in time too for the digital transition.
Posted on Feb 06, 2009
Stuck on 1 channel
Get a cable box from the cable company it will be cheaper than repairing the tuner. Then you use the tuner from the cable box instead.
May 07, 2010 | RCA 27R410T 27" TV
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
Nov 12, 2009 | RCA F36650 36" TV
I have an RCA 36 inch tv, the color is messed up, it has a round circle and it will not change channels
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | RCA F36650 36" TV
Tv worked until I unplugged it and moved it, now it won't turn on.
Ok try connecting it to another plug see what happens if that does not work then more than likely your tv set blew the main fuse which is located on the power supply right where the power cord comes into your tv set, you can get that fuse in any electronic store and change it out yourself just be very careful,hope this helps thank you.
Aug 15, 2009 | RCA F36650 36" TV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
Older 36 inch rca crt tv broken
Your high Voltage anode button that connects into Picture tube may have came lose Rember Picture Tube if not broken Holds 36,000 volts if not discharged, Have you Look under chassis to see if board it cracked? Sounds like your FBT?
Dec 23, 2008 | RCA D52W23 52" HDTV CRT TV
RCA 36
I got an RCA 27" TV from someone who had moved it to another room but found it was "blurry" after moving it. I brought it home and tried all the suggestions I had found online but it was still blurry. I looked at the back of the TV and found 2 tiny knobs on the right (from the back view) which I began to fiddle with while looking at the screen. It fixed the blurriness immediately! I now have a beautiful screen.
Apr 30, 2008 | Toshiba 36A40 36" TV
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
RCA F36450 36" TV Logo
1,449 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
