Question about Canon P1-DHV Calculator
I lost owners manual
I can't get the paper to feed into machine. Finally got it in but the machine will not print. So must not have the paper in correctly.
  • bonnie_hendr Feb 09, 2009
    I finally got my paper in right, but did not know to push the print button to make it print dumb huh. Now my problem is I need a new ribbon or ink because it is printing but too light to read. Guess I need to go to Walmart to see if they have what I need now. Bonnie Hendricks
  • 73 Answers
Call Canon at 800-828-4040. Select technical support. You actually get a live person.
They can e-mail you the manual in PDF format. It takes about 5 minutes.
The manual is not available on Canon's site.
Posted on Feb 06, 2009
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Our fax machine is sending faxes fine, but will not print in coming faxes. It keeps asking for paper (which is in the fax machine), then it sounds like it's working, then stops. We turned it off to see...
The paper isn't properly loaded. remove the paper then there should be a lever near the paper loading section that you push or pull to let the paper enter the feeding area. put in paper and return the lever to the proper position. check your owners manual. to get a manual try www.sharpusa.com .
Dec 16, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
"manual feed insert paper". the machine is stuck with this message brother mfc 7840N
This means at some point the machine was told to copy or print from the manual feed. So you need to put some paper in the manual feed so it will print out and clear the message. You can try turning off the power, sometimes this will clear the message as well.
Aug 25, 2010 | Office Equipment & Supplies
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
How do I use manual feed on the brother mfc 7820N printer/fax/copier?
The manual feed slot located in the front of the machine above the paper tray.
  1. Slide the gray paper guides to fit the size of the paper
  2. Using both hands put the paper (side to be printed, face up) in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the Brother machine feed the paper in a short distance.
  3. You must then go to the application that you want to print to the paper and use that application's paper settings to set the paper size, orientation, font, style, etc
  4. Good luck trying...
May 20, 2010 | Office Equipment & Supplies
How do you fax a document that is 11 by 14 inches?
Most fax machines and printers will scan and fax an 11x14 document. Just check your owners manual to see if any settings need to be changed AND contact the person you are faxing to let them know to put 11x14 paper in their machine, or some of the print may be lost if the fax will be printed on two 8x11 sheets.
If you don't have your owners manual, post a question and include the manufacturer and model number of your fax machine or printer and one of us will look it up for you.
Feb 10, 2010 | Office Equipment & Supplies
Paper roller on the left side of printer will not feed the paper
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Can't figure out how to print on statement sized paper.
After I had been attempting to adjust the paper guides in the feeder tray to accommodate statement-size paper, I finally "discovered" the drop-down door to the manual feed tray.  Duh!  This is a networked printer that I've only ever used for printing letter and legal sized documents until now.
May 28, 2009 | Lexmark T640 Laser Printer
Brother dcp 7010 How to print envelopes
size.
Using both hands put the one sheet of
paper feed roller.
Let go of the paper
May 16, 2008 | Office Equipment & Supplies
Canon P1-DHV Calculator Logo
207 people viewed this question
old marine
old marine
