Question about Acer Aspire 3003LCi Notebook
Flickering screen on startup
I have a Fujitsu Esprimo laptop. Everytime I on the laptop, with AC power or battery, the LCD screen will appear a white flickering screen. Sometimes, it will load back the XP screen after awhile, sometimes, I need to tilt my LCD panel to and fro or even hit it slightly to get the XP screen. The laptop is running on a XP pro OS SP 2, dual core, 2GB ram and ATI Mobility Radeon HD 2400 display. Can anyone advise if this is hardware fault or software fault? (Softwares installed-Norton, MS office, IE, software bundled with laptop)
  • christankc Feb 06, 2009
    Thanks gyan and RM. gonna sent it down to the service centre and DEMAND they get it FIXED.
  • Anonymous Mar 31, 2014
    My Sony SVF 15A1C5E as locked up after downloading new Sony software for my Sony Z1 mobile. The screen has freezed and I am unable to shut the laptop off. Nothing seems to work. What can be done to reset the laptop and switch it off?
  • 479 Answers
If the screen is flickering at fujitsu logo and as you told the problem this seems a issue with display pannel cable so please get it refixed or replaced and the issue will be resolved.
Posted on Feb 06, 2009
  • 73 Answers
Sounds like hardware. Several possibilities come immediately to mind:
1) Backlight is going bad. (It's a fluorescent light).
2) Bad inverter
3) Loose or bad cable in laptop hinge
If the picture is OK using an external monitor, it's probably one of those three.
I've used these guys before for screen repair: Unknown document title.
http://www.notebookmechanix.com/
My fujitsu U9210 not connects with external monitor
Max. resolution external display 1920 x 1200 / true color / 60 Hz
graphics brand name Mobile intel gMa 4500M HD
You need to set screen resolution to this if your monitor will take it.
Apr 04, 2014 | Fujitsu Siemens ESPRIMO MOBILE U9210...
When I switch on my laptop it seems dim in brightness until I change that using fn and f8. Is there a setting to avoid doing this everytime i switch my laptop on??
Go to Start > Control Panel> System and Security> Power Option> Change Plan Settings> Right down on the bottom you will have Adjust Plan Brightness (if you are running windows 7). For windows 8 should be under power options as well. Good Luck!
Jan 13, 2014 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Have fujitsu esprimo mobile laptop screen keeps switching itself off intermitantly (approx every 30 secs) anyone know why????
system software is probably corrupted, have it fixed by a capable computer guy or if it is still under warranty have them fix it for you
Oct 25, 2012 | Fujitsu ESPRIMO MOBILE V5515 V5555 V5535...
How do i find out what type of inter face card my fujitsu laptop has
Click "Start" and then "Control Panel."
Click "Appearance and Personalization."
Click the "Adjust screen resolution" link under the Display heading.
Click the "Advanced settings" link.
Click the "Adapter" tab. You will see the properties of your graphics card.
hope this helps
Oct 12, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
My Fujitsu siemens esprimo mobile M9400 laptop screen was fade (white color). When I connect to extra monitor via monitor output, computer is working well. How can I solve this problem?
Dear User,
Good day, maybe you need to press the function key of your laptop plus(+) the split monitor key in your keyboard it is usually placed in F5 key.
Apr 16, 2011 | Fujitsu Siemens Computers & Internet
I have Fujitsu Siemens ESPRIMO MOBILE V6505.When i push power button it didn't start on; led E is on and nothing else even thought i use charger. Thanks for your helps
maybe the power on button is damaged, try to push it on it's edges or switch off the charger and take out the battery for 5 minutes.
Jan 20, 2011 | Fujitsu Siemens ESPRIMO MOBILE V6505...
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
How do i change my lcd screen on my Fujitsu Siemens Esprimo Mobile V5535
The LCD screen is cracked, that why it is black.
You can a Google search for replacement screens on the Internet, I found LCD Parts resonable for parts, service and DIY info.
Use this link to get to their WEB site :-
www.lcdparts.net
Jun 28, 2009 | Computers & Internet
Assistance replacing Esprimo Mobile screen
get a flat screw driver and start undetaching it from the corner
Mar 05, 2009 | Fujitsu Siemens Computers & Internet
Acer Aspire 3003LCi Notebook Logo
400 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
