Question about Nintendo Fit Battery Pack for Wii
Problem with wii fit rechargeable battery pack
I have the wii fit rechargeable battery charger. When I put the usb in the port and hook everything up the red light is not coming on showing me that it is charging. what do I need to do?
  • Anonymous May 25, 2009
    I have the Nexxtech Rechargeable battery pack for Wii fit and it has worked in the past but suddenly it doesnt seem to be charging
We need to play with cable or no i have the same proplme
Posted on Jun 21, 2011
Ever since using the rechargeable battery pack for the balance board, our balance board keeps stopping due to an "interuption with the connection". I have to wait for the light to stop blinking then turn it back on. Meanwhile it picks up right where you left off so I miss some stuff. It's fully charged! Any help?
Posted on Aug 18, 2010
  • 39 Answers
Make sure the battery charger is connected, and that the port connections are tight, other than that I would say you have a faulty charger.
Posted on Feb 06, 2009
Can I charge my HP 632 (that has rechargeable batteries in it; from the USB hooked to a solar charger?
You may recharge the batteries using any compatible charger. It doesn't matter to the camera whether the charger is powered by a nuclear reactor or a hamster running in a wheel. Bear in mind that the HP M632 is NOT a battery charger. The batteries must be recharged outside the camera.
Dec 12, 2012 | HP Photosmart M632 Digital Camera
I have a wii system and use the energizer nimh battery pack with the wii charger. When I put them in the charger it flashes red. Reminds me of my camera battery charger, but I have learned how to reset...
I have this issue with one of the batteries in my set. (Purchased last summer). It is a PL-7522
It seams to be the battery, as I have tried combination of charging ports and controllers. The other battery seams fine.
Dec 24, 2010 | Energizer NiMH Compact AA/AAA Battery...
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
To charge my ilo do i have to take out the battery and put it on a battery charger or just plug it into a regualr phone charger?
The iLO I had used just a normal battery you replaced it when it was dead. If you have a rechargeable battery you can recharge it in a charger made for these battery's. But to my knowledge hooking up to the USB port with a charger will not charge the battery.
Jan 17, 2010 | Audio Players & Recorders
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
I have the rechargeable battery pack on in my wii fit balance board. I the power keeps cutting out and it is saying communication is lost on the balance board, and to push the power button again. This...
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Jan 27, 2009 | Nintendo Wii Fit for Wii
Wii fit board rechargable battery pack
Have you tried regular batteries, the UK model takes 4 AA batteries or is the US model different? Cheap third party battery packs made in China are rubbish and never work for long if at all.
Aug 14, 2008 | Nintendo Wii Console
Problem with wii controller charger
Sounds like you broke your remote to me. did the batteries leak on your remote? If so, try to clean the contacts on the remote (the spring on one side and the flat one on the other). You may need to use a nail file to scrape off the gunge.
Now, why did this happen? Did you put rechargable batteries in your wiimote before you put it on the charger? And if so, did yo put the CORRECT TYPE of rechargables? There's a big difference between nickle cadmium (Ni-CD), Nickle Metal Hydride (Ni-MH), and Rechargable Alkaline. Putting the wrong type of battery, or a non-rechargable battery into the wrong recharger causes leaking, explosion and fire... as the charger and the batteries warn you of all over.
Feb 04, 2008 | Nintendo Wii Console
Nintendo Fit Battery Pack for  Wii  Logo
1,939 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
