Question about Zenith MBR3447 Remote Control
Need Programming Code for Zenith Remote MBR3457
I have the remote and TV - it's an older model and I need to reprogram but don't have the 3-digit code... anyone have a manual with the codes?
  • 1 more comment
  • dazzling40s Feb 13, 2009
    i have a 1995 zenith 51 inch tv. i lost the original remote but i was able to obtain a mbr3447 remote. i need the code for the tv
  • spongbergm Mar 10, 2009
    I need help to reprogram my TV my remote is MBR3447T. Presently it skips channels unless I enter them by specific number
  • Anonymous Apr 20, 2009
    i dont know the 3digit numbers
    Champion:
  • 226 Answers
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
Posted on Apr 23, 2009
  • 4 Answers
Try this link for FREE instructions/manual/codes:
http://users.usinternet.com/n0flq/multi-brand_remote.html
Posted on Feb 23, 2010
Phillips universal code for zenith tv
Try these codes. 0738,0826,0284,0888,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
I have a zenith tv , n i have a digital stream converter box connected , the remote. Got un programmed i need.the code to program the remote to the tv , can you help me ?
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Aug 04, 2010 | RCA 3-Device Universal Remote
I need the code for a rca remote (rcr311w) for a zenith TV
I am very happy to help you reprogram your RCA RCR311W for your Zenith TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up on this remotes device code list.
I hope that helps.
Mar 07, 2010 | RCA 3-dev Universal Remote Remote Control
I have remote (MBR3457). I need a code for a Sony DVD Player.
Hi try 522
heres a link to codes for ZENITH>
http://www.thompsontv.com/zcodes.html
Feb 04, 2010 | Zenith MBR3447 Remote Control
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Need instructions for this SK64002 Zenith model remote I can't seem to get it programmed and can't find any instructions anywhere.
Zenith SK64-002 remote programming. Begin programming by holding down the power and mute buttons together until the red LED stays lit. Remote codes are entered like this: Use V- for first digit. CH- for second digit. V+ for third digit. When you are done, press the mute button (small button in center) to enter. Example: Older Sony TVs are code 801. Press the V- button 8 times. (The CH- button doesn't need to be pressed since the second digit is zero.) Press the V+ button once. This is how you enter the code for 8-0-1. Press Mute to save.
Mar 30, 2009 | Televison & Video
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
ZENITH REMOTE CONTROL
COMO PROGRAMAR UNA TV ZENITH
Jul 29, 2008 | Televison & Video
Need code for zenith Televison
I don't know if you need the 3 or 4 digit code for your specific remote. I have found the site that provides the codes for your universal control.
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Zenith HDTV
If you have a 4-digit remote, it should be 0634
If you have a 3-digit remote, it should be 634
Zenith standard TV (there's a bunch)
3-digit: 000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338, 358
4-digit: 0121, 0009, 0050, 0078, 0091, 0138, 0059, 0131, 0038, 0111, 0134, 0153, 0064, 0004, 0135, 0226, 0227, 0245, 0247, 0252, 0266, 0288, 0310, 0338, 0358, 0023, 0058, 0039, 0001.
I hope this helps!
T-Mo
Feb 09, 2008 | GE RM24911 Remote Control
Lost code and instruction book?
Orion Codes: 035, 121, 135, 191, 394 Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.pdf Hope this helps, Good Luck :) Please Vote
Jul 10, 2007 | GE RM24911 Remote Control
Zenith MBR3447 Remote Control Logo
2,262 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
