Question about Kenmore Elite 45986 Front Load Washer
Washer Not Starting
When you push what cycle you want it lights up but when you push the start button nothing starts. Checked down below to see if anything in the drain that would plug it up. It was clear, the last time we had repair man out that was the problem. So can you give me something to go by that might work.
    Scholar:
  • 99 Answers
Hi my name is joyce,
I am not quit clear what is going on with your machine but lets start with what is simple first, start with unpluging machine for 60 secounds and this will reset machine and replug it back and see if this will do the trick. let me know if this works.
thanks
joyce
Posted on Feb 06, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore 800 series washer started draining but stopped 3/4 of the way and now won't do anything at all
Put the machine into the spin cycle and start as normal. Then with the lid open take a item like a pencil and depress into the lid switch where the lid pushes down on a switch. If machine starts spinning remove and replace lid switch. Let me know.
Feb 01, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loading washer
I am having trouble starting the washer . I set the cycle on casual and press the start button and the washer sensor showed to " Done" instead of starting. I only bought it three months ago.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore dishwasher
needs a new control panel/ touchpad assembly very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 27, 2007 | Dishwashers
Kenmore Elite 45986 Front Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Robert Rankin
