Question about HP Computers & Internet
TV freezes - is it the graphics card?
My picture freezes for no apparent reason. If I reboot, the media center starts working again. my tv freezes during games then when i turn off the tv and turn it back on it goes for like 30 sec then does the same thing... i dont get it
  • 73 Answers
Possible overheating issue. If it's a graphics-intensive game, it tends to push the CPU and graphics hard harder than when you're just surfing the web, which generates more heat.
Trying opening the case and see if you have dust bunnies - any buildup of lint or dust on air intake areas. Canned air is good for getting rid of that. Also verify that all fans are spinning. The fan bearings will seize up after a while and will probably need to be replaced.
As a temporary measure, try removing the side panel on the case if that's feasible. May help some with cooling and can tell you if your problem is heat.
Posted on Feb 06, 2009
Norcent Technologies PM-4201 42 in. EDTV-Ready Plasma Television that turns itself off within one second. Then the remotes don't work and I have to unplug the tv. Is the tv shot?
That might be a factory fault don't hesitate but to take it to the retailer if still under guarantee. Or phone the manufacture for a quick respond.
May 03, 2017 | Norcent Technologies PM-4201 42 in....
Display drivers wont work
Dear,
There are two points.
1. Ensure that you are downloading and installing the correct driver for your graphic card.
2. If the fist condition is fulfilled then unplug the graphic card and check the system with the built in graphic card in motherboard and install its driver and get its functionality. When you are ensured that system is working with its own built in graphics then plug it again properly and install the driver. Ensure the proper plugging of your graphic card. Sometimes improper plugging of card cause this issue.
The second step will confirm the two things. one that your motherboard is functional with its own card and the reason is extra graphic card plugged in slot.. and the 2nd is that the card itself causing the issue not the motherboard and the issue was replugging...
best of luck...feel free to ask more...
Mar 06, 2012 | Computers & Internet
Cant get my tv out to work
Boot in safe mode. (press F8 during boot, just before windows starts loading). If the desktop is then displayed, the graphics card is still functional. I am not very familiar wih NVidia graphics drivers but you may want to check (after a normal reboot) in the NVidia control panel. FIrst try cloning the image (both screens get same picture and resolution) If that doesn't work, try lowering the resolution. When you have found a resolution where the tv does display a picture, extend your dektop to it, set your monitor back to its default resolution, and keep the tv at the resolution you've found works.
If nothing out of all this helps, I think you should try reconnecting (and replacing, if all else fails) the cable connecting PC and tv. If that doesn't solve the problem either, well..then I'm out of ideas. The only option left is that some hardware is broken, and I can't fix that from here.
What you could try is to reinstall your graphics driver, although that is not liely to help, since you've only installed it recently.
I hope this solves your problem,
Yannick.
Dec 10, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
TV tuner and Cablevision box incompatible
You need to go through the Setup in Media Center. Open Media Center. Click on "TV and Movies" and then "Set up TV"
Good luck.
Mar 19, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Media Center - Live TV not working
I am assuming your computer is intel. Have you tried reinstalling your video/graphics driver? Go to the intel website and search for a driver update.
Apr 09, 2008 | HP Media Center m7260n (EG642AA) PC...
How much memory do you have installed? Graphics require a lot of memory (ram) to operate correctly. By the time you run the OS, support software, and all the other things on your system, it takes up memory space. Check that first. Even some graphics cards can add memory to them, check that too. My advice is you can't have enough memory in today's computers. Then check all you settings for optimal performance. If you change "one" setting, run your system before you change another setting. That way you'll know what worked.
Sep 11, 2007 | HP Media Center m7250n (ED842AA) PC...
Windows XP Media Center, systems freezes; suspect Radeon x600 xt
Make sure all of the fans inside your computer are still functioning. One of them could have stopped working and it is causing the card to over heat.
Jun 05, 2007 | ASUS RADEON X600 XT, (128 MB) Graphic Card
Windows Media center recorded TV playback
Some possible causes can be system heat causing the video card to freeze. Sometimes it can also be related to the video driver or MPEG2 decoder. Make sure to use the right decoder and filter for the video playback.
Mar 06, 2006 | Microsoft Windows Media Center Edition...
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
