Question about Epson Stylus CX6600 All-In-One InkJet Printer
Not printing I have an Epson CX6600. I have changed all ink cartridges and charged them. When I command my computer to print anything it OK's it, goes thru all the demands and etc , but only blank pages come out. Acts like it is printing a job but Nothing! Need Help. Thank You. zwmy24@aol.com
  • 1 more comment
  • Anonymous Feb 09, 2009
    I replaced all the cartridges and charged the printer.  The command to print results in lots of noise and activity, the paper moves through the printer but comes out blank.
  • mskatz Feb 09, 2009
    Does not print....pages are blank
  • John Sparozich May 11, 2010
    Did you remove the tape from the cartridges?
    What Operating System are you running?
  • 106 Answers
Try to check if the type are not remove in the cartridge then check if the printer head cable of the print head is ok.. ^^ if not you need to tighten it up.. or maybe the pritner head cable is damaged
Posted on Feb 06, 2009
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson cx5500 prints only with black cartridge???
Yes it will still print with black provided that your computer still detects the colored cartridge tanks.If you are certain that there is still some ink left on the colored ones, take them one by one and shake them hard as if you are trying to distribute the ink evenly. After that, you need to do a test print to utilize the colored inks.
Sep 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Mostly yellow print out
i think your color cartridge are not jetting fully..other nozzles are not jetting ..the main reason for this is low ink level and clog nozzles..
you need to replace your cartridge if you satisfies with your ink ...try to wipe the cartridge in a wet cloth ...
May 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
New ink cartridge not working properly
if you open the lid of the printer you should have the ink slide to have you take it out.
I would unplug the printer for about 5min and then plug it back in and then it should ask you to redo it again.
Nikki2913
Nov 20, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Sep 01, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Changing Cartridges
I inspected the users manual, there it writes:
The steps below to replace an ink cartridge: Caution: Leave the empty cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. To ensure good results, use genuine Epson ink cartridges and do not refill them. Other products may cause damage to your CX6600 not covered by Epson’s warranty. 1. If an ink cartridge is empty: Look at the LCD screen to see which cartridge is empty, then press the x Color button. If an ink cartridge is low: Press the Setup button to enter Setup Mode, then press the green button next to the LCD screen until Replace Ink is displayed. Then press the x Color button. 2. Lift up the scanner 1314127a0e502194c0d970046a123efc.png 3.Wait for the ink cartridge holder to move over, then open its cover.
4. Identify the cartridge you need to replace. Press in the tab at the back of the cartridge, then lift it straight out. Dispose of it carefully.
5. Before unwrapping the new cartridge, shake it gently four or five times. Then remove it from its wrapper.
6. Insert the new cartridge into the holder. Press down firmly until it clicks into place.
7.
Close the ink cartridge cover.
8.
Lower the scanner.
The CX6600 begins charging the ink delivery system and “Charging . . .” appears on the LCD screen. Wait for charging to finish before using your CX6600.
Caution: Never turn off the printer while “Charging . . .” appears on the LCD screen, unless the CX6600 hasn’t moved or made noise for more than 5 minutes.
Jan 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Colored bars across page
I would try changing the ink cartridges and if you don't have a new set at least take out the ones you have and reseat. Also check Epson's site for new drivers. Try printing from a different program.
Mar 28, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
