Question about Sony HVL-F1000 TTL Flash
Broken part The plastic piece that slides into the camera shoe is broken on the flash unit. The part is part of the unit that attaches to the base of the flash unit with four screws. How or where do I find a replace part?
    Novelist:
    Scholar:
  • 64 Answers
This part, the 'hot shoe assembly' is much stronger than it looks and holds all the weight of the flash mounted to the camera in those 2 little slots.
Yes, you'll need to replace it.
Are you comfortable with electronics and small components. There are small springs and pins/ball bearings/contacts in there when the cover is removed and wires may have to be soldered in place (I can't remember if there is a plug for those wires inside).
Try here to buy the part you need or contact Sony service (I'm assuming you're in the USA):
http://esupport.sony.com/US/perl/model-accessories.pl?mdl=HVLF1000
Keep us informed if this was good or you need further help.
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 06, 2009
I have broke my hot shoe nissin (DI 622) where can i get replacement of the hot shoe....
I have broke my hot shoe (the contact piece that slides into the camera) is there a way to just replace that piece
Apr 28, 2011 | Nissin Cameras
I have a Di622 Nissin Flash, the base is broken. The part that slides into the hot-shoe. Would like a quote on the fix.
i have a Di622 Nissin Flash, the base (hotshoe contact piece that slides in camera) is broke is there anywhere I can order the replacement piece?
Jul 20, 2010 | Nissin Speedlite Di622 TTL Flash for Canon
Internal flash not working because of non compatible flash installed
Solution:
Look at the external flash socket.
With the camera in "normal position", i.e., poiting away from you, you shoul see a very small (I realy mean very small) piece of plastic under the rigth inside of the flash shoe... it is the "external flash sensor". It probably is stuck. Work with the point of a knife to try and release it.
In more detail, if you look carefully at the external flash shoe, the are two metal pieces that will help create some pressure. So the flash holder (shoe) is made of two parts: a very rigid one and the metal blades that create the pressure. Look under the blade located nearest to the shuter button.
If you can locate the plastic piece (black in my camera, but can be white) try to have unstuck.
Worked with my camera.
regards
Mig
May 24, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Broken flash handle
Loctite makes a glue suitable for this type of repair. It is very strong and does not melt the plastic if too much is applies, unlkie super glue.
Apr 02, 2009 | Quantaray Cameras
Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Mar 11, 2009 | Olympus Safe Hot Shoe to PC Sync Flash...
Hot shoe
If the flash is not sitting securely on the hot shoe when attached to the camera you may want to send the camera body to Olympus repair center for service. Their telephone number is 800-622-6372 option 2 and then option 3 to discuss the repair process and pricing if needed.
Dec 29, 2008 | Olympus EVOLT E-500 Digital Camera
Snapped off flash; how to remove flash mount from camera body?
What kind of camera ?
Take the batteries out of the flash. Try to fit the pieces together and hold down with pressure it should just slide off. Don't touch any bare wires if showing.
Nov 24, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Replacement shoe for Sigma EF-500
I had the same thing happen. Sent it into Sigma, they replaced it for 50 bucks.
Feb 03, 2008 | Cameras
send it to a sigma agent thay can replace the broken part
Nov 02, 2007 | Sigma EF-500 DG for TTL Flash
Sony HVL-F1000 TTL Flash Logo
198 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
