Projection
TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the
video to look normal. When its out of alignment the video will look
3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,
Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi,
Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
- TV shuts off after powering on - TV may also make a chirping noise.
Here are some
photos of convergence problems.
Here is a quick test....Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as
flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a
solutionCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise
calling a shop or if you want to do it yourself get a complete kit with instructions and support from
www.TvRepairKits.com
The picture is just not as sharp as it was before. I was out of the country for a few months and when I got back it seemed the colors blend with each other and it takes away from the clarity. It's almost like there is a haze. I also tried all that I could, adjusting the sharpness and brightness and such but it did not help.
