Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
Volume Control stopped working
I really messed up my computer's sound capability. Somehow, the volume control icon stopped showing up in the taskbar. I have an HP873n Media Center PC (before 2005). When I go into Control Panel the sound choices for volume control are greyed out. Please review the newsgroup posts that outline the lack of progress so far:
Thank you for your two posts. I did get the information from the system: Name: Creative Audigy Audio Processor (WDM) Mfg: Creative Technologies, Ltd. Status: Error Device ID: PCI\\/EN_1102&DEV_0004&SUBSYS_005B1102&REV_03\4&11C9F252&0&00F0 However, this driver was not on the system before I messed it up. The driver was something like SB Audigy. This was the one that I overlayed when I installed the new copy of a sound driver (maybe the wrong one). When I try to enable this, the system crashes, when I try to uninstall this, the system crashes. The only way the system works is to disable it. But then I cannot use sound. I have openned a support call with Creative and I hope they can help me. My version of MCE is the original one, before 2004 or 2005. So I do not know what to do? Regards, keffert "S.Sengupta" wrote: > Alternatively you can see here:- > > Start>All Programs>Accessories>System Tools>System > Information>Components>Sound Device. > > regards, > S.Sengupta[MS-MVP] > > > > S.Sengupta wrote: > > > This is entirely a driver related problem.You also did a wrong choice-by > > selecting safe mode with net working. > > What driver do you see in device manager?Select the driver and right > > click on it and select properties.Under the General tab you will find > > the driver's name.Select Driver tab you will get driver's version > > also.Hope this helps. > > > > regards, > > S.Sengupta[MS-MVP] > > > > > > keffert wrote: > > > >> Hello, > >> > >> I openned Device Manager, expanded Sound. This did not reveal the > >> sound card - no model. Before I had overlayed the SB Audigy driver, > >> it indicated it was Creative Labs (the manufacturer) but no model - > >> only PCI slot 1. Now I have attempted to uninstall the current driver > >> and it seems to work, however after rebooting, it crashes part way > >> through the boot, and returns to the safe-mode screen and I can only > >> enter via safe mode (I use with networking). I can still see the > >> driver in the Device Manager. The only way to keep the computer > >> running is to disable the driver. So I am still stuck. > >> > >> Thank you for your help. Any other suggestions? > >> > >> > >> "S.Sengupta" wrote: > >> > >> > >>> Open Device Manager,expand Sound, video and game controllers by > >>> clicking the[+]sign.This will reveal the sound card.Note down what > >>> specific model of sound card is there.Now visit the manufacturer's > >>> site and search for this very audio driver. > >>> You should uninstall the old driver from the device manager,reboot > >>> the system before installing the new driver. > >>> > >>> regards, > >>> S.Sengupta[MS-MVP] > >>> > >>> keffert wrote: > >>> > >>>> Hi, > >>>> > >>>> When I installed the new driver (the name was SB Audigy) from > >>>> Creative's web site it was a version from 2006, and after rebooting, > >>>> the system tray indicated that it found new hardware. I had been > >>>> using a 2002 version (that is on my MS MCE CD). I did not uninstall > >>>> the old driver first. How do I determine the "correct model number" > >>>> for the device? There are lots of Audigy drivers. Also, the > >>>> installation of the driver instructions were to close all programs, > >>>> even though the screen was completely occupied by the backround > >>>> graphics of the installation program. Would this matter? > >>>> > >>>> Thanks for your help, > >>>> keffert > >>>> > >>>> "S.Sengupta" wrote: > >>>> > >>>> > >>>> > >>>>> Uninstall the specific driver from the Device Manager.Restart the > >>>>> machine.Now your system will find the new hardware. > >>>>> Before updating the driver make sure you are installing the correct > >>>>> model number for the device from the manufacturer's site. > >>>>> > >>>>> regards, > >>>>> S.Sengupta[MS-MVP] > >>>>> > >>>>> keffert wrote: > >>>>> > >>>>> > >>>>>> Thank you for the suggestion. I attempted to reinstall the SB > >>>>>> Audigy driver > >>>>> > >>>>> > >>>>>> from Creative Labs, and the computer fails to boot now. I > >>>>>> reverted back to > >>>>> > >>>>> > >>>>>> the older version of the driver in safe mode and it still didn't > >>>>>> boot. I then disabled the sound driver in safe mode and it boots ok. > >>>>>> > >>>>>> Do you have another suggestion? > >>>>>> > >>>>>> keffert > >>>>>> > >>>>>> "S.Sengupta" wrote: > >>>>>> > >>>>>> > >>>>>> > >>>>>> > >>>>>>> I shall suggest you to install the latest audio driver from the > >>>>>>> manufacturer's site. > >>>>>>> > >>>>>>> regards, > >>>>>>> S.Sengupta[MS-MVP] > >>>>>>> > >>>>>>> keffert wrote: > >>>>>>> > >>>>>>> > >>>>>>> > >>>>>>> > >>>>>>>> I have XP Media Center Edition - upgraded with service pack 3. > >>>>>>>> My Volume Control stopped working recently: > >>>>>>>> 1. No icon in system tray/taskbar. I cannot 2. When using > >>>>>>>> Sounds and Audio Devices Properties, the entire Device area is > >>>>>>>> greyed out and not accessible, including placing icon in > >>>>>>>> taskbar. My sound card is Creative SB. > >>>>>>>> 3. My keyboard volume control just shows the low volume on the > >>>>>>>> monitor and cannot change the level. > >>>>>>>> 4. I can run the program sndvol32.exe (and restored this file > >>>>>>>> from CD again) and the GUI comes up with the channel levels but > >>>>>>>> not the master volume control level/balance/mute settings showing. > >>>>>>>> > >>>>>>>> I have checked several threads and cannot seem to get help from > >>>>>>>> them. I would appreciate very much some assistance on this. > >>>>>>>> > >>>>>>>> Thanks, keffert > >>>>>>> > >>>>>>> >
  • 1 more comment
  • t_keffer Feb 06, 2009
    I have tried this before. I tried it again today, and it did not do anything. Currently, the only way to run the computer is with this driver disabled. Otherwise, it will only run in safe-mode. I have not located the original driver disk.
    jsparo asked what the OS is. It is Windows XP Media Center Edition (2002).
  • John Sparozich May 11, 2010
    You can try going to www.hp.com then select support & drivers, enter for live chat support and see if they may be able to help you.
    Good Luck.
    What Operating System are you running?
    Problem Solver:
  • 13 Answers
CLICK ON START BUTTON AND GOW TO YOUR CONTROLL PANEL WHEN U THERE OPEN SYSTEM FILE AND CLICK ON DEVICE MANAGER WHEN YOUR DEVICE MANAGER HAS OPENED CLICK ON THE DROP DOWN THAT SAYS SOUND GAME AND VIDEO CONTROLLER AND ONTOP AT YOUR MENU ICONS YOU WILL SEE A SIGN WITH A RED X TO UNINSTALL CLICK IT NEXT TO IT THERE IS ANOTHER SIGN TO DETECT FOR NEW DRIVERS CLICK ON IT WINDOWS WILL REPAIR IT FOR U PROBLEM SOLVED
Posted on Feb 06, 2009
I want to display my volume icon
Dear Costmer,
please Followup ,
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
amit.mishra.lenovoservice@gmail.com
Feb 13, 2015 | Toshiba Satellite Computers & Internet
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
My dell volume icon is deleted
By default, the Volume icon is not displayed when you initially install Windows XP on your system.
  4. Click OK.
  5. Click OK.
Thanks, Hope this Helps
Please Rate;)
Gary
Jul 30, 2013 | Microsoft Windows XP Professional
Sound not comeing at the takbar speak not show
Show the volume icon in the taskbarIf you end up finding to impractical notification area to have the speaker icon displayed inside the taskbar, you can tell Windows 7 to resume showing the volume, same steps as before:
  • Click on the start menu, and type "volume"
  • Select the Volume's dropdown menu, and change its value from "Off" back to "On"
  • Click OK to confirm and close the Control Panel
Windows 7 has now resumed displaying the volume icon in the taskbar!
Else IF windows XP
goto control panel click sound and audio device then check Place volume icon in the taskbar.
Aug 15, 2011 | Computers & Internet
How can i return my volume icon in my taskbar...
By default, the Volume icon is not displayed when you initially install Windows XP on your system. To Display The Volume Icon follow the steps given below: -
4. Click OK.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 13, 2010 | Computers & Internet
The volume icon on my taskbar has been deleted from my computer how can I download it again
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
Hope it helps.
Nov 22, 2010 | Microsoft Windows XP Professional
Sound icon not here
To place a volume icon and sound icon in the taskbar follow these steps.
For Volume icon:
1. On Control Panel, double click Sounds & Audio Devices icon.
2. Select Volume tab
3. Check the box for "Place volume icon in the taskbar"
4. Click OK.
For Sound Icon"
1. On Control Panel, double click Sound Effect Manager
2. Select General tab.
3. Check the box for "Show icon in system tray"
4. Click OK.
I hope that solves your problem.
Please comeback and rate this answer. Thank you for using Fixya.
Aug 16, 2010 | Microsoft Windows XP Professional for PC
Can not show volume icon on my pc
XP view
Control Panel
->sound,speech, and Audio Devices
->Sound and Audio Devices
->sound And Audio Properties
->check "Place volume icon in the taskbar" box
Classic View
Control Panel -> Sound and Audio Devices->sound And Audio Properties->check "Place volume icon in the taskbar" box
Hope it helps.
Aug 14, 2010 | Microsoft Windows XP Professional SP2
I have lost the volume control icon from the desktop toolbar and want to restore it
To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
May 21, 2009 | Dell Inspiron 1501 Notebook
Volume on computer too loud i can't find the volume control icon
go to control panel->sound and audio devices-> in volume tab see that "place volume icon in the taskbar" is checked. then you'll get your icon back in task bar.
Apr 19, 2009 | HP Compaq Computer Speakers
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
1,066 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
