Question about Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel GWL10 question to Rescue Tech
Thanks, Rescue Tech, for your response, I much appreciate it.
You that possibly the diverter tab was causing the water to drain back into tub instead of draining. Do I access this by lying machine on its side and getting to it from underneath or do I need to remove the drum?
ms01007
  • Monika Schrauder Feb 07, 2009
    thank you Recue Tech, for your detailed explanation and links to the part and manual. I have drained the washer just as you indicated in the diagnostic mode with pitcher (worked like a charm) and was surprised at how much water was actually still in there seeing that there was only a little water in the bottom of the tub.
    I am going to tackle the diverter diagnosis this weekend and hopefully it will be as you suggest and I can fix it myself. I will follow up with a comment on the forum.
  • 145 Answers
First scoop out the water or run the pump in diagnostics mode and use a pitcher to bail out the water as it flows from the recirculation hose. Next, tip the machine back enough so that you can set something like a gallon paint can or other sturdy object under the front left corner of the machine to keep it propped up while you work under it. These machines are actually very lightweight. You do not remove the tub to service the diverter. There is a single 3/8" hex head bolt (which also is recessed with a phillips head) that secures the diverter to the base via a white nylon band. Remove the bolt, then remove the band, which is actually wrapped around the drain hose . Now remove the two wires, and the three hose clamps and all three hoses. Pop the valve out and take a close look at that diverter, if it is broken at the tab, this will be obvious.
The diverter is part number 426862P. You can order one here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=54
Posted on Feb 07, 2009
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel diverter valve malfunction? or control module issue
If the tab is not broken take it out of the washer and remove debris from diverter valve
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Nov 18, 2017 | Washing Machines
Fisher paykal GWL10 top loading washer
Hi. I work on these machines every day.
The problem with your model 10 is that the diverter valve is not in the DRAIN position, so when the pump runs, it is sending the water right back into the tub. The issue is one of two things-
Either the tab on the diverter valve has physically broken off and the machine needs a new diverter valve, or there is a short in the machine's controller and it is sending a constant signal to that valve, causing it to never be in the DRAIN position. When the diverter is NOT energized, the flap is at rest and the water will go out the drain. When the valve IS energized, the water is supposed to go thru the recirculation hose.
You want to check that diverter valve first and formost. That's going to tell you what you need to know. Look closely at it and you'll see if the little tab that goes from the wax motor to the flapper lever is broken off. The diverter valve is located down underneath the tub in the right rear, it has three hoses attached to it and two wires. It's grey in color and the little wax motor is brown.
If you would like to obtain a service manual, you can get them from http://www.fisherpaykelparts.net
Feb 05, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
I have a gwl10 and during the wash cycle there is water coming in but the drain pump keeps running during the fill cycle.
The pump itself is supposed to run during the fill portion of the REGULAR cycle. It is supposed to be mixing the incoming fresh water with your laundry detergent and pouring the solution on your clothes as the tub rotates slowly. If the water is draining out of the machine, then there has been some sort of issue with the DIVERTER VALVE. It either has a broken lever on it or an object has become wedged in it, holding it open all the time. If you try the PERMA PRESS cycle, you will probably find that cycle will work, as it does not use the recirculate function.
I would check the diverter valve first. You can tip the washer back and remove the hose clamps with no tools and shine a light up inside and look for an object. You also can inspect the lever and will clearly see if it is broken.
If the washer needs a diverter valve, the part number is a 426862P and is easy to change. You can get them from Fisher Paykel Parts:
http://www.fisherpaykelparts.net/111-4/Diverter-Valve-GWL10-11-15.php
They also have downloadable service manuals (but I have pretty much told you what you need here)
Here is the GWL10 manual:
http://www.fisherpaykelparts.net/115-15/GWL10US-Service-Manual.php
Dec 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Nov 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
F & P - GWL10 - Diverter Valve issue
Sounds like you might have the drain hose too far down the stand pipe and it's siphoning, try bringing the drain hose up a little.
Jul 15, 2008 | Fisher and Paykel Washing Machines
Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Mar 29, 2008 | Washing Machines
Fisher & Paykel GWL10 US won't spin
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher paykel gwl11 won't drain
This machine was made similar to a lighter.When it breaks you throw it away.
Jan 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
284 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
