Question about LG WM-2277HW Front Load Washer
Leaking Door LG WM2277HW
I have changed the large grey gasket...still leaking. When the rinse cycle begins and the water starts to pour out from the top of the door, the basket begins to spin and the water overtops the grey gasket and spills over into the glass that is on the door goes thru the crack into the door and then down the front of the machine. The old gasket was fine, but when I took apart the glass on the door water had collected inside? It kinda seems like there should be a seal on the door also? I tried the shifting of the door and every other suggestion made. I have done all of this after I had a repairman come 3 times and did everyhting that he knows to do? HELP!!!
  • dmyu Feb 07, 2009
    Hey thanks for the suggestion. I already tried that and ran the rinse and spin cycle by itself with no soap?? Still no luck. What do you guys think of putting a silicone around the glass on the door? We have spent several hours watching and taking apart things to figure out where the leak was coming from and it is definitely the glass b/c when you take apart the door water collected inside. Thanks again for your help.
    Dawn
  • dmyu Feb 15, 2009
    YEAH!!! I got it finally. Well...my husband figured it out. He bought a ribbed piece of plastic rubber, siliconed it all the way around the door at the edge where the glass meets the metal and NO MORE LEAKING!! After many attempts by the repairman 6 months or so later it is fixed. I didn't want to celebrate too soon so I washed my usual 2-3 loads a day for almost a wek now and NO MORE LEAKING. I hope this helps all of you looking for a do it yourself fast, inexpensive solution.
    Scholar:
  • 99 Answers
Hi my name is joyce
have you tried using he detergent, if not this will make the suds back up in the door and push their way out the bottom of the door even if you have replaced the gasket. the front loaders are very sensitive when it comes to sudsing. if they get to many suds in pump they will give you problem, use about 1 tbs oil in wash ben and run cycle to get rid of suds that may be in pump, then see if this gets rid of problem, if not you may want to call a service tech. let me know if I can help find you someone.
joyce
Posted on Feb 06, 2009
Leaking water out of bottom and will not brew a full cup
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Apr 14, 2013 | Keurig Platinum B70 Coffee Maker
I have a LG WM2277HW front loader washer . The door doesn't close all the way. It locks, but is kind of loose. I don't get any error messages, and it cycles fine(washes fine), but as soon as it starts...
If it is physically possible on your machine I would suggest that the door catch need adjusting, either that or it's broken but the door sensor still thinks it's OK ;-0)
Suggest a service call required ;-0)
Sorry,
John C
Mar 02, 2011 | LG WM-2277HW Front Load Washer
Leaking water under front edge of machine?
Open the door and gently pull on the grey rubber gasket and check all around it for holes / tears. There are three tiny holes in the 'wall' at the bottom that are supposed to be there, but you should not see any other tears. I just found a large tear on mine that causes leaks when I run very large loads. I am going to try to fix it with Gorilla Tape, otherwise I will probably have to buy the whole new gasket. It seems like it would be a real pain to replace!
Apr 30, 2010 | LG WM-2277HW Front Load Washer
Water Pouring out of door, appliance stuck on wash
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked.
Some common leaking trouble makers....
Leaks at the door:
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket
for parts you can get it from
www.repairclinic.com
Nov 21, 2009 | Candy Dishwashers
During the wash and rinse cycle I have water seeping out of the bottom of the door on my LG washer. WM2277HW.
Give a good clean around the door seal and make sure you close it firmly.This does usually fix it but you can also twist the door manually to help the seal.
Oct 04, 2009 | LG WM-2277HW Front Load Washer
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
LG WM-2277HW Front Load Washer Logo
340 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
