Question about Insignia IS-LCDTV32 32 in. Television
Insignia 20 inch TV Frozen
Will not change channels or volume.  You unplug it and plug  and plug it back in....it comes back on without hitting the power button.
    President:
  • Insignia Master
  • 1,779 Answers
Defective Main control panel, I would take it to your nearest service center for an estimate first.
Posted on Feb 19, 2009
Hi, i was trying to turn down the volume on my tv (its an insignia) and i accidentally hit the channel button and i think it messed up the programming of my tv to my cable box. what should i do?
try setting the tv to channel 3 or 4. if that does not work, try finding a "input" or "source" or video" button on the remote and cycle thru them, this should get you back up and running. remember to have the cable box turned on during this so youll see when it comes back on.
Mar 24, 2011 | Televison & Video
Insignia/tvflat32" automatically channel will change to ch8
i hve the same tv and the same problem. heres the fix; you must take off the back cover so you have the back of the lcd exposed. its about 30 r so screws to get it all off. once you have the back panal off look at the side where the power button channel button and volume ect. button are. follow the wire thats connected to that, to the motherboard. simply unplug this wire from the mother board and use your remote control to change channels and power on off the unit from now on.
Sep 30, 2010 | Insignia NS-LCD37 37 in. LCD TV
Cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Mar 29, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
131 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
