Question about Canon Office Equipment & Supplies
The ink absorber is full canon ip 4500 - Canon Office Equipment & Supplies
    Genius:
  • 2,785 Answers
Plz check the link
link
Posted on Feb 06, 2009
Canon ip 4500 ink absorber problem
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 26, 2011 | Canon Pixma iP4500 InkJet Printer
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber full canon ip 4500
Just follow these steps to fix this,
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 28, 2010 | Canon Pixma iP4500 InkJet Printer
Canon ip 1300 ink absorber is full. how to empty
you can not empty it without going to service centre?
Aug 15, 2009 | Office Equipment & Supplies
Ink absorber full
You can probably do this once as the ink absorber will start to expel in onto the place where printer is on.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Jun 20, 2009 | Canon Pixma iP4500 InkJet Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber on canon iP 1600
Try reading THIS .
Hope that fixed ya...
Geno
Apr 04, 2008 | Office Equipment & Supplies
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
135 people viewed this question
old marine
old marine
