FixYa.com
Tags:
Vivitar 5000 Ring Light Flash
Off-brand 'ring' flashes, TTL? (by 2 users)
By man1 - usenet poster
Following by earlier post on off-brand flashes, I
would like to ask some questions on 'ring' flashes
not made by camera manufacturers. The most
important question for me is which of these can
TTL with a Nikon FA and can be mounted on 62mm
filter threads. Not available at all? If so, is it
*very* difficult to manually adjust the exposure
with a ring flash? How limited would the selection
of f-stops be?
My 100-300 zoom + 6T allows a slightly larger than
life size magnification with about 10 inches
between the lens front and the subject.
Regards
Fei
posted and emailed discussions/responses welcome
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Nov 22, 2007
will the Sunpak DX-12R TTL Ring Light Flash work with TTL on the Olympus E 510 or the Olympus E-3:
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Pasty
Pasty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I've broken up my comments into two portions and imbedded them in the
original text.
Grover
: I have just purchased a Sunpak DX-12R, which is to my knowledge the
: only off-brand alternative to the Nikon SB-21 macro flash. Vivitar
: make a ring flash (model 5000?) and Sunpak has a DX-8R, but neither of
: these are TTL flashes.
Grant,
The DX-8R IS TTL and is a no-focussing light single circular flash tube unit
Grover Larkins
: Overall, I am satisfied that the DX-12R is preferable to the SB-21.
: Here are the advantages of each flash:
: DX-12R: - much cheaper (factor of two). I paid $218 + $30 (dedicated
: module) at B&H in NY
: - offers 1/2, 1/4, 1/8 and 1/16 (SB-21 has only 1/16) power
: ratios
: - has four, quite bright, focusing lights (SB-21 under
: batery power has only one, which is not much use)
: - did I mention it was much cheaper?
: - modular foot allows use on various brands of camera with
: full TTL (I'll probably never use this feature), and
: dedicated module can be shared among various flash heads
: (good if I ever buy another Sunpak dedicated flash)
: SB-21: - not actualy a ring flash. Has two independent linear
: flash-tubes which can be fired together or alone (this
: allows directional lighting and shadows when desired
: to expose surface detail, eg. coin photography)
: - offers separate under-exposure and over-exposure indicators
: - perhaps slightly more ruggedly built
: - has an optional flash difuser for short working distances
: (eg. reversed wide-angle lens)
: Nikon flashes have always been _quite_ pricey, and frequently not as
: fully featured as off-brand alternatives. In this case, the choice is
: not as clear-cut, but unless you _really_ need directional
: macro-lighting (and this can be achieved with the DX-12R by some
: homebrew masking of part of the ring-flash), I think the Sunpak is the
: better buy.
: I have two problems with the DX-12R. First, it only comes with
: mounting rings for 62mm and 67mm filter-sizes. This is _very_ anoying
: as I didn't discover the lack until I returned from my road-trip to
: NY. Of course I can use a step-up ring to mount the flash on my 52mm
: Micro-Nikkor 105/2.8, but I would prefer to have a non-kludgey mount.
: Sunpak do offer optional mounting rings in other sizes, but I have so
: far had no success obtaining one in Toronto (where the DX-12R sells
: for a ridiculous $CDN 838 list price, and is bought only by
: well-heeled dentists). The second problem is that the distance/f-stop
: scales for the flash's manual mode are calibrated for a 50mm lens.
: The flash manual tells me to see my lens manual for other focal
: lengths. Of course, my Nikon lens manual is mute on the subject of
: distance/f-stop calibration for Sunpak flashes.
: This brings up my questions. The manual is contradictory about the
: meaning of the distance scales. In one place it says the distance is
: to be read off of the lens scale, implying they are film-plane/subject
: distances. In another, it specificaly states they are flash/subject
: distances, and NOT camera/subject distances. Since the flash is on
: the end of the lens, I really don't know what they're trying to say.
: The second question is, how should I recalibrate the scales for my
: 105mm lens? I would presume for small magnifications that a 50mm and
: 105mm lens would require the same aperature to obtain a correct
: exposure, but that for higher magnifications the greater working
: distance of the longer lens might require slightly larger aperatures.
: Anyone care to comment on this? I will naturally be using TTL mode
: most of the time, but the ocasional macro-fill-flash at 1/8th power
: would be very nice, and I can't achieve that unless I know how to
: re-calibrate the scales for my 105mm lens.
: grant..
Comment on the Last here -- Use a flash meter and a steel rule to measure flash
to meter distance for the marked reproduction ratios on the micro-nikkor and
compile a table of f-numbers for each power setting on the flash unit at these
distances. I find a flash meter to be a practical necessity as the power ratio
settings can be off considerably -- heck the flash capacitors are usually
-20/+50% capacitance tolerance units and they change with age and amount of use
as does the tube's output
Grover Larkins
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
Spriratone (or SP Systems) sells two units:
1) Macro Ringlight - auto/manual, 80 deg.angle
of coverage, auto range 30 - 95 cm at f 5.6
@ 100 ASA, GN 16 @ ASA100/DIN 21 in feet,
recycles in 10 sec. 120 flashes per set of
batteries (2 AA). Attaches to front of any
lens (adapters included). PC cord also included.
$134.95 US
2) Super Ringflash - Auto/manual, Nikon dedicated
unit available (+ $10), GN 37 @ 100 ASA (ft.), .25 -
10 sec. recycle, 1/800 - 1/20,000 sec. flash
duration, 60 deg. angle of coverage, 100 - 800
flashes per set of batteries (4 AA), attaches to
front of any lens (adapters included), Hot shoe and
PC sync. connection. $299.95 US
SP Systems/Spiratone
P.O. Box 6199
Pittsburgh, PA 15212-6199
USA
1-800-221-9695
I hope this helps. I don't have any personal experience with these units.
I usually use a Dolan-Jenner fiber optic ringlight I modified to fit
the end of my 55mm Micro-Nikor. The color temperature is a pain, but I
am almost always shooting black and white.
Good Luck,
Paul Cotnoir
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
these are TTL flashes. I have been meaning to post my initial
impressions/questions, but your query got me off my butt.
ratios
better buy.
grant..
Can you Help with these Flashes problems?
Flashes
lights out
I was in my tanning bed and it... Answer This...
Flashes
firmware for the pdr-3300...
do you still have the newest... Answer This...
Flashes
Restriction Code NOKIA 6030
Hello, I bought a cellphone in... Answer This...
Flashes
Built-In Flash
I'm only 17 and am somehow... Answer This...
Flashes
Hanimex TZ1 Flashgun
Looking for genral operating... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
