Question about GE JVM1440 Microwave Oven
GE Microwave Model JVM192K heats intermittently
Usually it works fine, but if something is not hot enough after the initial heating, I will start a new cycle or add an additional minute.
When the minute (or whatever added time) is finished, basically nothing happened. I'll try it again, and it works fine.
I would say this happens 2 out of every 10 times.
Any suggestions for the determining the problem?
Thanks!
  • William Miller
    William Miller May 11, 2010
    When it heats less than normal, do the inside light, turntable and internal cooling still run, or are they cutting out?
    Any unusual noises? Isit louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
Verify the door micro switches.
Posted on Nov 14, 2017
SOURCE: Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Posted on Oct 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
djicenova
  • 319 Answers
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Posted on Mar 21, 2009
bjvom
  • 5 Answers
SOURCE: My GE model JVM1653 has problems when heating I
Take the 2 screws out of the top outside grill. Take the 1 screw out of the top of the control panel. Lift the panel slightly and it will tilt out and hang there. Try a cook cycle with the panel in this position. If it works, your problem is interference from your magnetron. It is very common on these units. I do not recommend adding EMI shielding with tin foil as many have been suggesting on the help sites. If you are still under warranty, call GE. If not, call GE and threaten to sue. This is a known problem with these units and they should have been recalled.
Posted on Jan 06, 2010
  • 2468 Answers
SOURCE: My JVM1653 loses power after 3 minutes of heating
it may have been the hi voltage at the magnetron,but the shut down is your heat thermocouple mounted on the magnetron side and when the mag overheats this thermocouple opens up and shuts off power to the mag to prevent overheating and fire
Posted on Apr 17, 2010
Our microwave starts, the turntable thing turns and the food heats a little but it is very, very quiet. Sounds like something didn't kick on.
If this oven had been in use for a while, you might have an intermittent magnetron. As they age, resistance builds up on some of the elements inside. Eventually they just stop oscillating, but some end up on the fence; not being able to decide to oscillate or not. They become intermittent for a while, and then eventually fail completely.
I have also seen intermittent high voltage rectifiers. They usually fail sooner, rather than later.
May 18, 2016 | Microwave Ovens
Tip
DANGER WARNING! Potential Hazard if your microwave was working and now doesn't...
If you have this model microwave and it was working fine, then one day it stopped heating items placed inside there are a handful of different issues that could be the problem. In my case it was intermittent, over a period of a few days it would sometimes work (heat) and sometimes not. NO MATTER if this is what your's is doing or if it stopped heating all together. If you decide to let it dry out, or not use it for a while to see if it was a one time occurrence, or whatever the reason, the first time you put something in and probably for the next 10 times at least (this assumes it starts to work again), make sure you are right there with it while it is cooking. Don't assume you can put something in, go do something and come back when the timer is beeping. There is a chance (as this happened to me) that your food inside will CATCH FIRE! Normal food item placed inside, no metal, nothing different than the numerous times before when this had been cooked but when we smelled smoke we came running. Fortunately it started and finished inside the microwave but that's not a guarantee, it could spread. Play it safe. Never had a problem like this before and never heard of a microwave cooking something until it caught on fire (especially since the time entered for the cook was 30 seconds) but it did.
on Sep 23, 2013 | GE JVM1850SMSS Microwave Oven
My GE over the oven microwave does not heat (1.5 years old). The heating and turntable stopped working at the same time. When you start it, it sounds fine, but nothing heats. You can hear a relay or...
It does sound like a relay malfunction or similar switch. Could be repaired but call for a quote or better yet, take it to a repair depot (probably cheaper).
Dec 13, 2014 | GE Microwave Ovens
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave model 721.80033700 won't heat
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
Mar 21, 2009 | GE JE1540 Microwave Oven
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1440 Microwave Oven Logo
136 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
