Question about Albatron Nforce2 (KX18D PRO II) Motherboard
Cannot boot up
I have a pair of Kingston DDR333(256mb each) ram newly bought,when comes to installation it failed to boot up. Checking on another slots,also the same thing happen. It just stuck on the BIOS windows. But then, when I try to use one RAM stick the things just work fine. Run a test on the other RAM stick also. Right now I managed to use only one memory stick..Need help....
  • dimdumdim Feb 09, 2009
    thanks thrazel...its fixed...
  • 106 Answers
Maybe you must reset the bios in the motherboard. try to open your system then look for a 3 pin in the motherboard near in the CMOS battery.. it has a number 1,2 and 3 it is called jumper settings.... try to put the pin in number 2 and 3 then w8 after 10 seconds then gput it back to 1 and 2 in try to boot up.. ^^ i wish this could be help.. ^^
Posted on Feb 06, 2009
  • INHS INHS Feb 09, 2009
    no problem... ^^
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
Hi I have inherited an asus m2n mxse mobo with an unknown cpu in and fan,supposedly working. I have a stick of 1 gb kingston ram (DDR2-800 KVR800D2NG) in 1 slot. The board won't start, even into bios,it...
pj, the manual specifies, See page Viii and page
1-3. for the memory supported by the M2M-MX SE MB uses: Dual-channel memory. 2x240-pin DIMM up to a max of 2GB. Non-ECC 800/667/533 MHz
All dual channel memory comes in pairs. Also see page 1-13 before installing you're memory.
SS memory should be inserted into DIMM_1.
DS memory should be inserted into DIMM__1 and DIMM_2.
Provided below is Asus updated QVL list.
http://dlsvr04.asus.com/pub/ASUS/mb/socketAM2/M2N-MX%20SE/M2N-MX_SE_QVL.pdf
If you wish to install Kingston you'll need to buy,
KVR800D2NG not KVR800D2N5 as shown in the QVL list. Ran a search through Kingston’s site. Seems the memory you bought is not supportive for Asus MBs.
Cheers'
Mike
Feb 12, 2010 | Computers & Internet
Add paired ram, system will not boot
could be a bad ram stick, or a stuck stick not all the way seeded in the board, check these things and if all else fails, try new ram, even new memory can be faulty, like try installing 1 stick then boot, then other stick and vice versa, until you find which stick is bad
Dec 24, 2009 | HP Compaq dc7600 Small Form Factor PC...
Gigabyte ep45ud3p will not boot just installed
A friend of mine just purchased one of these boards and is extremely impressed with it but when he first bought it he bought some lower grade ram and had a lot of troubles with it. He went to Kingston ram DDR2 1366 and it ran perfectly. I don't know what kind you bought but the board is very picky about the ram. The other thing to try is unplugging the hard drives, cdrom and any add on cards except video and see if it boots. up. If this works then add your harddrives, cd and addons back one at a time.
Dec 12, 2009 | Computers & Internet
1GB seen as 512Mb
I think you are right, you have to update your BIOS, or try to change your Kingston to Super Talent or other compatible with your motherboard ram. Good luck!
Sep 12, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Bios changes
What are you changing? The motherboard or one of the peripherals such as memory or video card or drive controller may not like the setting or may be incompatible with certain options causing the problem. You may also want to see if there is a bios update to address the issue.
Good luck.
Dec 26, 2008 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Nov 24, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Installed new RAM, PC would not boot up.
Will the PC boot? It may just be loose. Try it again. The PC may not boot if it does'nt recognize the memory.
Sep 19, 2008 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Albatron Nforce2 (KX18D PRO II) Motherboard Logo
89 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
