Question about Bunn GR10 Coffee Maker
Directions Lost my directions how do you do the water again when you first turn it on
  • 131 Answers
Pour the water into the top, just as you would to make a pot of coffee, making sure the brewer is not plugged in. keep filling the brewer until the water comes out the sprayhead, then plug it in and let it heat up, and you are ready to brew.
By the way, operating instructions are available at no cost from www.bunn.com
Posted on Feb 10, 2009
Faucet still running
Change the O rings in the mixer.
Mar 10, 2014 | Danco Faucet Stem
Saeco Odea Go descaling
fill the tank with detergent and let the hot water run for about 15 seconds. Then turn off the machine for about 15 minutes. Then turn the machine back and let the hot water. Then rinse the water tank and fill it with clean water. Run hot water again to empty the tank. Fill clean water again and then you can put down coffee :)
Dec 02, 2013 | Saeco Odea Go
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Since we fixed our dish washer, the water prssure in the kitchen faucet is very low. A friend told me to clean the filter. where is the filter, and what do I need to open in order to get to it?
filter screen is usually just under where the water comes out. Cover drain so any parts do not get lost down drain. Just unscrew it counter-clockwise to loosen it up. Remove screen and clean by flashing water in bathroom sink until screen holes are clear. then re-install and tighten in clock-wise direction. All done after you check that water comes out again.
Oct 05, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Maytag side by side refrigerator and lost my manual. How do I remove the inside water filter cartridge, which rotates either direction but does not easily come off?
first shut of trhe water and then let the pressure off of the line by openoing up the water dispenser . then turn it counter clockwose and then it sjhould come right off
Dec 24, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
WATER IS NOT HOT
Hi mac3493,
I'm Harvey the Master Plumber.
Your problem is: WATER IS NOT HOT
The hot water for your d/w comes directly from your hot water heater. Sometimes the pipe length from the hot water hearter is very long, so when you turn on the d/w it's filling up with the water that 's been sitting in the water lines. By the time the hot water gets to the d/w it's already full. All is not lost. When you're ready to turn the d/w on, first turn on the kitchen sink faucet and let it run till the water is hot, then turn on the d/w.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Whirlpool Dishwashers
Lost directions to the cleaner.
Hi , check the water level and refill it .
Jan 21, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bunn GR10 Coffee Maker Logo
157 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
