Question about Fujitsu LifeBook N6100 Notebook
Five vertical lines have appeared (one at a time over a 8 week
Period) on the screen of my Fujitsu Lifebook laptop Model N6100 Notebook computer. Three of the lines are yellow, one is purple, and one is green. They are very thin and pose no real serious problem but I am concerned they may keep forming. They are becomming distracting. Does anyone have any suggestions?
  • 191 Answers
Five vertical lines on the creen cause LCD panel problem, you may try:
1) check the cable between motherboard and LCD panel drive board(back of the panel), need to open the LCD lid.
2) cean the cable plugs and socket at two sides of the cable.
still not fixed there is the hardware damage your panel or your motherboard.
you can keep using if the lines do not affect you job. because the repair cost higher
Posted on Feb 06, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
  • 537 Answers
It sounds like the flex ribbon cable has become loose from the connector on the motherboard. You might just try pressing firmly on the middle top of the keyboard or near where the hinge is located to see if the lines go away. If they don't then you might have to disassemble the Lifebook just enough to get access to this cable and see if it is loose.
I have three thin vertical lines on my Fujitsu Lifebook laptop screen. What causes this?
Usually it's a bad connection between the LCD panel and the column driver chip for those lines. It is often caused by mechanical stress (we all have war stories about laptop misadventures). Sometimes it can be repaired by gently massaging the edge of the panel (you have to take apart the display far enough to do this, and you need to know what you are looking at so you don't take apart too much). This is tricky; you can easily cause other lines to drop out.
If necessary, you can have the panel professionally repaired. There are companies that specialize in this work - they can replace driver chips if that is required.
Dec 27, 2010 | Fujitsu LifeBook C1320D Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
My laptop screen shows red,green, blue, yellow vertical lines and it whites out
Asides from purchasing and installing a new LCD screen you could try reseating the connectors.
Sep 11, 2009 | Fujitsu LifeBook Notebook
Vertical color lines on the display
this is due to fault in the screen take it to the technician
Sep 02, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
Fujisu lifebook problem.
Most likely a hardware issue already as how you described it. So your fan is not working? Your system is heating up already. It might also have gotten some damage on the video as well. You have to get someone check the hardware locallly.
Jun 02, 2009 | Fujitsu LifeBook C6631 Notebook
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
Spilled liquid on laptop keyboard
Search for a keyboard on eBay. Should be about $5-15. Type in "(model name) keyboard."
Mar 14, 2009 | Fujitsu LifeBook N6100 Notebook
Over the past 8 weeks, a series of five vertical lines have
You Will Need A Display Replacement..
The Circuit Board Attached To The Back Panel Of Your Display Is Failing.. This C-Board Is Not Repairable and is integrated into the Display screen panel. And Yes, They Will Get Worse... They Multiply, They'll Start Moving Up And Down and Left And Right, You Will Eventually Get A Blank Screen..
Feb 06, 2009 | Fujitsu LifeBook N6100 Notebook
Verdical Line
vertical lines mean you need to replace the screen. did you drop the machine?
Nov 30, 2007 | Fujitsu Fujistu ST1200 Notebook
Fujitsu LifeBook N6100 Notebook Logo
307 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
