Question about Sanyo Televison & Video
Sanyo CLT 2054 Screen has severe flicker, after a few minutes it will clear for about 1 second and then go to black. Sound remains normal. I have personally just replaced the inverter board that was earlier diagnosed. Evidently it wasn't the problem.
    Master:
  • 848 Answers
Hi
This may be the backlights and or the backlights power supply is in failure, or the drive board is not working properly.
Posted on Feb 06, 2009
  • 6,784 Answers
Im thinking this may be the tuner that is malfunctioning. i would try that next. if that doesn't do it, i would test the power supply board for minor solder breakage. hope that helps ya:)
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Remote control
Buy a original remote.Website 1-800-Remotes factory original.Get the original remote.
Dec 11, 2009 | Sanyo DS27510 27" TV
Tv mount for SANYO 2054
Read ur manual,go to ur tv website or go to Ebay.com or Amazon.com to buy ur model tv mount.
Sep 26, 2009 | Televison & Video
Sanyo clt 2054 dead.just a clicking sound, no picture no sound no power light. replaced main board same problem.
As there is no Power, there seems an issue with Power Supply. Might be a blown capacitor.
Do you hear any sound when you Plug on the LCD and the Button?
What i assume, it has to be the Faulty Power Supply Board. As you are not getting any power , you should have check the power supply board followed by main board .
Check the Power supply board and invertor circuit and replace it, if Faulty.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 02, 2009 | Televison & Video
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Feb 25, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have a sanyo vizon flatscreen that the power cord was lost
I need a power cord for a sanyo flat screen t.v. model # CLT 2054. My email as follows is kellykingonly@yahoo.com . Please let me know if you can be assistance in anyway. Thank you.
Jan 08, 2009 | Televison & Video
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
