Question about Acer Aspire 5000 Notebook
Wen i trn my cmptr on it goes 2 windos but it is completly frzn
When i turn on my acer 5000 it boots fine but is frozen on windows xp I can not move my mouse or reeboot with cntrl alt delete
  • 474 Answers
Sounds like it could be a few things.
1. could be the hard drive is failing
2. You could have a virus that is consuming all the CPU power and is causing lock up.
3. Over heating and its locking up.
4. Damaged windows files and it cant complete the start. if its this, try the following
Do you have your original CD that came with it, or at least a windows XP CD?
You will need one.
What you do is,
1st: Bot from CD. Start the machine with the Winxp CD in the drive, hit F12 for boot options, or whatever key function it is. Do this as soon as you turn it on,
2: select " Boot from CD" and press any key when it askes if you want to boot from CD.
3: It will load like your doing a fresh install of windows. Thats alright, its normal and no it wont re-install windows at this point.
4: Once it loads, it will have some options. Pres " R" for repair.
It will go out and to the command prompt after about 5 seconds.
5: once at the command prompt, type in exactly ( CHKDSK C: /P ) Dont include the ( ) . Then press "Enter key "
6: after it runs the disk check, normally about 3 to 5 minutes, It will finishand go back to C:/
Just type ( EXIT ), Enter key, and let it reboot.
you can remove the disk now or later, shouldnt matter, It will go to the options screen like before, but just let it default to the normal startup, or hit enter.
Windows should now load fine and you shouldnt get that message at startup anymore.
WHY THIS HAPPENED?, you may be asking.
For some reason, certain Dell Hardware and software conflict, usually when you have installed some new program, or for just no reason.
Your Boot Up files get corrupt or cleared and windows needs those to start.
What you did was re-installed those windows files.
Now copy and paste into a word document and print it out in case it happens again. Not likley but it could.
This works with any computer experienceing this issue, usually, unless there is something worse going on.
You can help other now that you know how and become a hero, make sure to charge them $10 though for your time:)
Let me know if this doesnt work and we can try something else.
Good Luck.
Posted on Feb 06, 2009
  • 458 Answers
This could be a few things..
1. Possibly Overheating due to clogged fan/heatsink fins
2. Faulty Video Chip.. Most Likely Due to OverHeating or Board Warp..
3. Bad Battery.. Very Common with the Acer 5000 and 3000 models.... If you have a bad battery, the laptop will do both, run extremely slow, lack of mouse and touchpad movement, and non-booting/Freezing issues...
Windows XP boots re-boots after installation of SP2
try removing 1 RAM then let it boot completely,
Aftrer a success boot shut it down then put back the RAM that you removed
if the above solution did not work reformat your PC and repartition it
pls rate if this thing helps
Jan 30, 2010 | Computers & Internet
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
My Acer Aspire 5100 is messed up ?
I had a laptop in my shop recently with the same problem. If you moved the machine at all it would blue screen. The problem was a connector on the motherboard that had came loose and was shorting the system out. I had to tear the machine completely down, and it took me hours to find it. With that said, you have a short somewhere on the board, whether it be a loose connection or bare wire, and it would be in your best interest to take it to a professional to find the problem.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Won't boot past black screen with blinking cursor
it didnt recover...acer prolly sent you the wrong cd's or you didnt use them correctly. Have you just recovered or have you tried a reinstall of windows?
May 17, 2008 | Acer Aspire 5000 Notebook
Installing windows xp
Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
Oct 29, 2007 | Microsoft Windows XP Home Edition
PC is hang up about 5 mins after boot up.
heat sink problem or
ram problem
re assemble the system
Oct 26, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5000 Notebook Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
