Question about Saitek Pro Flight Yoke System Flight Simulator
Saitek Pro Flight 3 lever throttle quadrant
Everything works fine except that the throttle, prop and mixture lever dont' allow progressive increment, they go from idle to 100% in just one notch making impossible to adjust speed, RPM or mixture as desired. Any thoughts??
Thanks
Dan
  • RSW_776 Feb 11, 2009
    I Have the Same Problem I Have tried downloading drivers thinking that it would fix this.
  • tom7104 May 10, 2009
    I have a problem , i connected the throttle too and i had no take off thrust it took the whole length of runway to reach 100 knots so could not take off. I tried reconnecting my ch throttle and the problem was till there. Basically i cant fly. Any ideas.
SOURCE: Saitek Throttle Quadrant wont go idle and full power
I had a similiar problem and after spending hours researching and looking at forums I figured out the a solution. Plug in the quadrant directly into your computer and then configure it. At that time make your necessary tweaks, i.e. null zones and sensitivity adjustments. After you get it to work properly there, then you should plug it into your yoke and everything should work fine.
Best regards,
Gary
Posted on Jun 21, 2009
luckyluke78
  • 333 Answers
SOURCE: Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Posted on Aug 02, 2009
SOURCE: Saitek pro flight multi panel won't work
exit present flight to general menue, minimize so you can access the "start" button then go to programms/saitek and select "lauch the Flight Sim 2004 plugin". All will work well.....exect the trim wheel acts in reverse!!
Posted on Jan 18, 2010
rh10
  • 122 Answers
SOURCE: I have two saitek pro flight throttle quadrants
To get the quadrants to operate four throttles, you need to assign AXIS not buttons, then you will be able to set them up.
Posted on Jul 12, 2010
rh10
  • 122 Answers
SOURCE: Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Posted on Jul 16, 2010
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
Worn out to fast at the top end of the throttle,can it be repaired,have already changed 2 over,replacement part or repair , many thanks js SAITEK THROTTLE QUANTRANT
Unfortunately Saitek does not have a repair service therefore no spare parts are available at all.
If your Throttle Quadrant was bought less then 2 years ago you should be able to get a replacement for it from your retailer or from Saitek.
Hope it helps...
Apr 07, 2011 | Saitek Pro Flight Throttle Quandrant...
Jan 01, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight yoke and quadrant stop working
I had a similar problem with Vista Home 32. Finally tried an old external USB 1.1 hub that I had laying around and now everything works all the time in FSX and X-Plane. It is rock solid. Can't make it fail even when I try. I also tried a USB 2.0 hub but had the same problem with that. I can't say for sure it will fix your problem but it is worth a try.
Oct 30, 2009 | Saitek Pro Flight Yoke System Flight...
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
Best regards,
Gary
Jun 14, 2009 | Saitek Pro Flight Yoke System Flight...
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight Yoke System Flight Simulator Logo
490 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Rob Emerson
Rob Emerson
juanmireles1
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
