Question about Garmin nuvi 260W GPS Receiver
Need Garmin GPS Fix Advice
My Garmin Nuvi 265WT screen appears to be damaged. The actual plastic covering does not appear cracked but when the unit is turned on, it looks like something has damaged the underlying LCD parts. I can still see some things and the unit appears to work fine, I just cant see 1/2 of the screen. I could probably fix it myself if I knew where to get the parts. Any ideas?
  • 1 more comment
  • fyarbrou Feb 06, 2009
    Thanks Mike. I will check that. Hopefully that is the problem.
    My suspicions are that there is internal damage. When I say 1/2 of the screen is black, this is not a uniform 1/2 but various areas with a central point along the unit's edge where lines of black originate from in all different directions. It almost looks like something stressed the screen along the edge and damaged the LCD beneath.
  • fyarbrou Feb 09, 2009
    My LCD screen is bad. I reseated the ribbon cable and this is not the issue. Does anyone know where I could purchase a replacement LCD screen that would work for a Garmin Nuvi 265WT?
  • pastorenos Mar 25, 2009
    I have the same problem except for the screen is not black anywhere. The two cracks make it so that the touch screen does not work properly. I am looking to buy the part myself and fix it or find out where I can get it fixed for cheap. Garmin will charge me $175 to fix it, but I can almost get a new one for that and this ones only 4 months old.
  • 537 Answers
It sounds like the ribbon cable that connects the screen to the controller might be seated incorrectly. I would check that.
Posted on Feb 06, 2009
I can fix your broken display or sell you a replacement screen
john_jackson@handheldclassics.com
garmin nuvi 300 series and 700 series displays
Posted on Mar 15, 2009
The Garmin 265wt is useless, you try to get to an intersection and the unit shuts down< any one out there with a solution?>>
I can help you reset and fix your Garmin Nuvi 265WT.
Not starting or shutting down, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Feb 18, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Garmin Nuvi 265WT Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to back up a copy of your Garmin Nuvi 265WT Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Garmin Nuvi 265WT Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Does your Garmin Nuvi 265WT Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 265WT GPS unit.
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
Cant unlock maps
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
Sometimes, a Hard Reset after the WebUpdate is what is required; that information is covered in the details through the links above.
I hope that helps.
Nuvi 265W Manuals here.
Feb 10, 2010 | Garmin nuvi 265WT Car GPS Receiver
As soon as I program address the screen goes blank.
Not starting, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Dec 29, 2009 | Garmin n?vi 265WT Car GPS Receiver
I NEED THE RUN SOFTWARE FOR GARMIN
I can help you reload the system software and fix your Garmin Nuvi 265WT.
I hope that helps.
Dec 28, 2009 | Garmin n?vi 265WT Car GPS Receiver
Will get satilite for a min. then nothing. what to do? garmin 265wt gps
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor or inaccurate GPS tracking, and taking a long time to acquire satellites, are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
I hope that helps.
Nov 18, 2009 | Garmin n?vi 265WT Car GPS Receiver
Garmin Nuvi 265WT voice prompts tell me way to late to turn as I approach turns and intersections. Many times I am already pass the left or right turn lanes before I am told to turn. Also addresses and...
I hope that helps.
Jun 05, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 265wt Shuts off then back on and keeps doing this
I hope that helps.
Jan 25, 2009 | Garmin nuvi 260W GPS Receiver
Cannot locate satellites
I hope that helps.
Nov 23, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
401 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
