Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
New Samsung 40" flat screen HDTV only plays in black and white
We have Direct TV and TIVO service DVR.
The menus do come up in color.
  • 98 Answers
You need to check the cables.
component with RGB -- you need to connect exact match the color.
Posted on Feb 06, 2009
Will a dvr/tivo built for direct tv convercablet to a cable tv service with a cable card from suddenlink its a sd80 tivo dvr mfg 2004
Unfortunately, DIRECTV TiVo DVRs will work ONLY with DIRECTV. They cannot be modified to work with cable.
However, there are many TiVo boxes that do work with cable and they are as low as $99. See, for example:
http://www.weaknees.com/4
http://www.weaknees.com/5
Oct 28, 2013 | Televison & Video
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung HDTV LCD 40" no video output
cheaper to throw away and renew ,some dealers are paying a scrap value for your old TV on a trade in ,trying to find a dealer that can repair this tv is very difficult because in most cases the spare is more expensive than a new tv
Mar 03, 2010 | Samsung Televison & Video
Playback in B/W
no you can't transfer then to another hard drive because of the format they have been saved in, burn them to dvd if you can, try reset the machine to factory settings, this in theory should ironout any clitches
hope this helps
regards
Nov 17, 2008 | Tivo R54040 140-Hours Video Recorder
TIVO HD DVR
OK, I had Dish network come out and install DVR HD. Had pixel des torsion viewing everything I recorded. They came out 3 time and replace DVR and check everything 3 time with no improvement. I had them remove everything.
I called Direct tv and they did the same thing. installed there dish and cables and DVR. Same problems. My question is? Is this the nature of this equipment or is there something they are missing.
Jul 11, 2008 | Tivo Series2 TCD649080 Video Recorder
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Non-HDMI Tivo connection
The solution I use is S-Video from cable box to TIVO, and from TIVO to TV. That gets you the highest quality signal that the TIVO can handle. To watch true HD signal, switch TV from S-Video input to Hi-Def input and tune to HD channel. I have an HD cable box connected to both outputs, your situation may be different.
Feel free to ask for more help.
Jeepster77
Jan 16, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Ilo 42 in. hdtv
If it's TiVo code, it's built in to TiVo's IR.
Otherwise please be a little more discriptive in exactly what you are trying to do.
Oct 25, 2007 | iLO 3200 32 in. LCD Television
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
81 people viewed this question
Henry  Thomas
Henry Thomas
