Question about Kenmore 22422 Top Load Washer
  • 537 Answers
Check this fixya link:
Posted on Feb 06, 2009
  • 1,902 Answers
Have you checked the belt to make sure that it is not broken or slipped off?
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTips for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ... for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repair for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Ariston a1435
Does it work before? Try reset the machine... 1.0 Turn off the machine. 2.0 remove the power supply from the main supply. Leave the machine without any connection for about 15 minutes. try again?
Sep 14, 2007 | Washing Machines
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
How To Fix A Washing Machine That Is Not Spinning or ...
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
Nov 28, 2015 | Washing Machines
does tube move by hand? does it have the correct amount of resistance when turning, or is it hard or too easy?
Dec 09, 2014 | Whirlpool Washing Machines
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 14, 2011 | Washing Machines
Kenmore 22422 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
