Question about Philips Magnavox Learning Universal Remote
Philips universal remote codes 33/07
I lost my manual, how do i get codes or how to code search????
  • mr_dowden Feb 08, 2009
    program instructions for phillips cl035a universal remote for sony tv
  • 57 Answers
Try these links:
Philips cl035a universal remote manual and codes
The remote model is SRU3003WM/17 and here is a link for the owner's manual:
http://www.p4c.philips.com/files/s/sru3003wm_17/sru3003wm_17_dfu_aen.pdf
Also here is a link for their device code look up tool: http://www.urc.philips.com/
I hope this solution is helpful. Please take a moment to rate this solution.
Posted on Feb 12, 2009
I lost my manual for my remote control universal Philips I need help for my codes to programming a DVD player Coby 154
My manual lists 0294, 0296, 0396, 0293, 0146, 0494, and 0091. You also should be able to use the code search function to find the code.
Turn on player. Press and hold CODE SEARCH button until red indicator stays on, then release CODE SEARCH button. Press VCR/DVD button once to cause red indicator to blink once. Press CHANNEL UP button (up to 300 times!) until player turns off then immediately press MUTE button to install code.
Good luck with that 300 times!
Sep 02, 2012 | Philips Universal Remote
Lost remote and trying to use a phillips universal remote but cant find code
Regarding your remote control, Philips Magnavox - universal remote control, below is a link to to the user's manual for this and a couple other remotes that share this model number. Click below, choose your remote and the click the PDF user's manual. In the search box, type in the word, "code" and all things pertaining to setting a code will be displayed each time you press enter.http://www.support.philips.com/support/find_product.jsp;jsessionid=32D289AB3A01E1801AE80FF55AF1E3FE.app106-drp1?userLanguage=en&userCountry=us&_requestid=515863
Hope I helped Dr Reed
Mar 17, 2010 | Philips Magnavox Learning Universal Remote
I have a remote contorl universal philips .i'm tring to makc my citezen tv work lost instruction manual serial numb 50804225
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
CITIZEN .... 002 112 402 407 502 512 701 805 906 319
Please rate this solution. Thanks.
Aug 24, 2009 | Philips SRT9320/10 Prestigo 20-in-1...
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
Philips universal remote codes for symphonics tv
try to ask a copy from the store where you bought the unit. or search in the internet. send me the model and ill help you search in the internet.
Dec 10, 2008 | Universal Remote Control Remote Control
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Remote code
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Nov 23, 2007 | Televison & Video
Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
Mar 20, 2007 | Philips PM435S Remote Control
Philips Magnavox Learning Universal Remote Logo
1,236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
