Question about Dell Latitude D620 Notebook
Dell Latitude D620 locks up when moved
The system boots up fine, I can work on it without any problems, but as soon as I move the laptop the screen goes blank and the system locks up. This is baffling, as all diagnostics show nothing is wrong with the hardware, but the slightest movement kills the machine.
  • merlin_dgs Feb 06, 2009
    OK figured it out, its the battery (may be a faulty battery, or something wrong with the connectors (personally thinking its a faulty battery)), system runs fine with battery out.
    I was testing with battery in because it was charging just fine.
  • 458 Answers
Is this when the ac adapter is plugged in?? Or on Battery??
Posted on Feb 06, 2009
My Dell Latitude D620 laptop will not boot up unless I hold the power button down. The computer will run fine if I keep holding the power button down. It will also keep running if I hold down any key. As...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 04, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a D620 Laptop.. when i turn on my Laptop i get the Eror : "I/O card parityinterrupt at F000:E1B5" Type (S)hut off NMI, (R)eboot, other keys to continue. how can i solve this Problem ...Please Help...
try going into the BIOS of your system upon powering your laptop as soon as you see your Dell Logo keep on tapping f1 till you get a different screen or if the system beeps when you tap on f1 then stop it should boot into your system BIOS and give you options,
normally for dell it should have a phoenix BIOS try setting your bios to defaults then save and exit the bios if still it does not fix you issue then you can try reinstalling windows and its drivers .
Jun 03, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
How to restore my D620 to factory settings without a CD?
Hello there!
Well its impossible to restore any of todays laptops without their factory os dvd/cd. You could setup new operative system and make your laptop simmilar to what it was on factory settings, or you can search dell to send you that same cd/dvd on your post mail to your house.
I suggest you read http://www.dell.com/ and contact them in order to solve your problem. Hope i helped you! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Dell Latitude D620 Notebook
Dell Latitude D620 does not turn on
The MOST likely senario that I've seen with similiar indications involved a hard drive that is slow to spin up to speed. Hence why multiple attempts, with the drive not coasting to a full stop between attempts, the drive finially makes it to operating speed and the system boots.
Jun 10, 2009 | Dell Latitude D620 Notebook
Dell latitude d620 wont turn on
Did you upgrade the RAM when you upgraded to Vista. The D620 does not have the resources to run vista as pre-configured and requires, at the least, a memory upgrade. 1gb or greater is recommended.
Please upgrade the ram, or try F8 during boot for Safe-Mode and see if your RAM is not the issue. To check the amount of RAM you have:
Press and Hold Windows Key + PauseBreak
If you still have 256mb or 512mb vista is likely to barely crawl.
Let us know what you find.
Apr 17, 2009 | Dell Latitude D620 Notebook
Dell Latitude d620
how can i unlocked my laptop latitude D620 i forgot my password. now i cant get in it
Jul 02, 2008 | Dell Latitude D600 Notebook
Screen resolution resets to 800x600 after every reboot when d/port is connected.
You may have to set the monitors resolution to match the pc as they may be different.
Jan 13, 2007 | Dell Latitude D620 Notebook
Dell Latitude D620 Notebook Logo
268 people viewed this question
Alun Cox
