Many possibilities can cause this.... The Pick Up Rollers could be worn out and not picking the paper up correctly. Something blocking, or catching in the paper path The Fuser unit rollers could be sticking, going bad.. The Exit Delivery could be warped, cracked. After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-207 Grayscale Copier
Why does the Sharp MX 4501N go into a "clear data" mode for over an hour? No printing or...
(More)
Why does the Sharp MX 4501N go into a "clear data" mode for over an hour? No printing or copying can be done during this time.
Copy commences and then jam on the right side of machine after the paper receives the toner and...
(More)
Copy commences and then jam on the right side of machine after the paper receives the toner and prior to hot area. Does not appear to go though this second set of rollers.
57 college green maynooth ireland.i where can i get a now moto for the sharp AR 206.help me out...
(More)
57 college green maynooth ireland.i where can i get a now moto for the sharp AR 206.help me out please.
the stupid Sharp AR-207 fax won't stop printing the same thing over and over-- the fax information...
(More)
the stupid Sharp AR-207 fax won't stop printing the same thing over and over-- the fax information border
