Question about Whirlpool Duet GHW9150P Front Load Washer
Sd shows on the control screen
Stops mid cycle and sd shows on screen
    Scholar:
  • 99 Answers
Hi my name is joyce
you have to many suds in machin's pump you have to reduce the amount of suds that are in pump, use 1 tsp of oil where you put your powders and run cycle with no clothers in washer, this will get rid of the suds. first unplug washer from wall for 60 secounds and replug back up. set for normal wash and use the oil only. if this does not work you will have to call service tech. remember to always use he detergent it is low sudsing. all front loaders need this detergent.
thanks
Joyce
Posted on Feb 06, 2009
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Washer stops at rinse cycle and give the ul code F1
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Why would it stop mid cycle? You can hear the engine trying to start.
It is not the engine but the motor that makes the noise. perhaps it can be a mechanical issue that stops the machine at mid cycle due to friction on the drive or it can be due to faulty control panel or even a dirty/ clogged drain pump.
Sep 07, 2012 | Fisher and Paykel Washing Machines
Stop in mid cycle
washing machine hotpoint hvl211 stops in mid cycle and wouldn't take the conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 03, 2012 | Washing Machines
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
Whirlpool Duet GHW9150P Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
