Question about Dometic Rooftop RV Air Conditioner
Cam Replacement at 190,000 miles
I just bought a 1998 Silverado P/U with the 7.4 Vortec. A mechanic is saying I need a new Cam and related parts to the tune of 1800.00 to 2000.00! Is he doing unneccessary work to make money. How can I solve this Problem Economically
  • 6,784 Answers
This will depend on what your symptoms are. i would like to discuss this with you over a chat. there are many question i need answers to before i can give you a good answer. i will say at this time, if you are experiencing massive misfiring in multiple cylinders then. i would suggest a look at the valve springs and valve seal as well.
Posted on Feb 06, 2009
  • Michael Masters
    Michael Masters Feb 06, 2009
    if you could give a list of these related parts and your symptoms. i could better assist you. thanks
How can I remove gear-to-gear timing cam?
images for How to remove a gear to gear timing cam ...
DIY Timing Chain and Gears Removal - YouTube
? 6:31
https://www.youtube.com/watch?v=eMXO1bvUCMs
Dec 30, 2012 - Uploaded by Bullshitkorner
The most important part when doing timing gears on a engine is ... Doing this inside the engine bay will be a bit of a pain in the axx but it is doable for sure. ... How to build a Chevy 383 Part 3: How To Install a Cam & Timing ...
Head removal & replacement, Timing Chain & gears also ...
? 3:28
https://www.youtube.com/watch?v=CnXtwR1N0Og
Apr 28, 2012 - Uploaded by No1hmfic Gibson
Head removal & replacement, Timing Chain & gears also, 97 Chevy S10 2.2 ... replacing the head gasket in a chevy cavilier 2.2 liter 4 cylinder - Duration: 9:38. ... 98 S10 Vortec V6 4.3 Intake Gasket Replacement Part 1 of 5 ...
Chevy S 10 2.2 L Engine Timing Chain Replacement Guide ...
? 7:30
https://www.youtube.com/watch?v=8nX5HARPSF4
Feb 03, 2016 | 1998 Chevrolet S-10 Pickup
5.7 vortec multiple misfires
I'm with you leaning on a maf/sensor, also be sure to clean out the Idle Air control...usually hand in hand...another issue could be "bad gas" did your GMC sit for any period of time? Try adding two bottles of gas tank injector cleaner...I prefer the STP super concentrated in the black bottle...Walmart is definitely the cheapest for these bottles by 2 or 3 bucks...Hope this helps.
Jul 20, 2012 | 1998 GMC Sierra
Intermittent shutdown 1996 silverado
if it is a Vortec check the crank shaft sensor and if it is t.b.i have the control module checked at local parts store
Jun 11, 2012 | 1998 Chevrolet K1500
My 1999 silverado has a 4.3 vortec engine an keeps burning up distributor caps an rotor buttons it has a miss in it when your driving it and your re barely pressing the accelerator the code says it has...
A lot of miles could mean a worn cam lobe..I recommend a compression check..make sure you are using OEM spark plugs for sure..and the correct battery..Some parts stores have weak parts also that has happened to me before and it drove me crazy..also racing spark plugs or wrong plugs will cause incorrect fire and it will force the engine to miss but will still run.I really need to know how many miles are on the engine and if it has correct plugs or not...Metalpoet
Sep 20, 2011 | 1999 Chevrolet Silverado 1500
1999 5.3 vortec silverado 4x4. Engine intermitient hard start.
Pull the plug and inspect the color, are any of them whitish, could be coolant leaking into the combustion chamber,
May 13, 2010 | 1999 Chevrolet Silverado 1500
Engine runs extremely rough, seems to be fuel related, new fuel pump & filter installed, pressure good, run 2 bottles of injector cleaner through. Can't get to stay running under load. 1998, chev....
Have you changed the plugs, if any are fouled out or if any are worn, it takes more to fire it under load and may be spark knocking because one of the plugs can't fire off all the gas and cause it to skip or idle rough.
Jan 18, 2010 | 1998 Chevrolet K1500
1998 Honda Accord transmission problem
This transmission have shift solenoids that are mounted on the outside in my personal experience I have rectified shift problem with these transmissions by simply change a solenoid or two. My recommendation is to put this vehicle on a code scanner and find out what is at fault first. If its a solenoid just replace, they are a dealer only part and that should take care of your problem. Good Luck and thanks for using FIX YA
Jan 01, 2009 | 1998 Honda Accord
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
