Question about Frigidaire FEF352 Electric Kitchen Range
Display shows f1
Broiler stay on
  • 750 Answers
Hello jrill42
Welcome,
Display shows , F1
this means your Circuit board is defective / Replace control board
You need a tech to do this work .
Please remember to leave a solved rating before you sign out!
Thank You Huum
Posted on Feb 06, 2009
Laptop starts up then the screen stays black
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 08, 2012 | Computers & Internet
Why does Sony laptop screen stays black when booting?
Mar 31, 2012 | Computers & Internet
I asked about a broiler that came on while in the bake mode and would not shut off until the range is unplugged. I forgot that it displays F1 on the readout.
Hello, Thank You for using FixYa. I will be helping you today. F1 is a failed erc(clock)
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Ovens
Oven broiler will not go off., when i close oven
This is a control board issue. The contacts on the broiler relay may have welded closed. You options are to replace the controller, or disable the broiler relay output. The controller is the most expensive part of the range. The model numbers shown do not match a Kenmore stove, so I couldn't give you a better answer. Check on the back of the unit for a model number and go to Sears Parts site to find what you need. If the oven works but not the broiler you may be able to disconnect the output from the card and continue to use the rest of the range. I did this while waiting for my part to arrive. The Sears store should have a wiring diagram if you can't find the one that is usually found on the stove. Mine was in an envelope on the back of the unit, though I have seen them attached to the backside of the rear cover. Mine was just a quick connect and I pulled it loose, taped the end up and continued to use the rest of the range.
Jan 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Oven just turned off
It sounds like your microprocessor in your control board is damaged. You can leave the power off for as long as a week to see if it will reset. If it comes up the same way, it's an electronic problem with the display driver. Frigidaires usually display an "F1" code. Any way, power down, wait at least 3-5 days, power up, clear, reset time and see how it goes. If it happens again, you may have to get a new oven control board/display.
Jul 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Fridgidaire FGF 374 CCSA oven and broiler do not come on
F1 means it is a defective eeprom. The software is incorrect. Replace EOC. Check inside the bottom drawer on the right side: there was an envelope with the troubleshooting and maintenance diagrams in it.
Jan 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven showed F1 as problem. oven nor broiler is working.
if its a gas range then check the pilot light is lit. thats always the best place to start
a model number might help diagnose your problem
Oct 27, 2008 | Frigidaire Kitchen Ranges
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
F1 Code on display
The model # is incorrect...please post correct m #....
Aug 27, 2007 | Kenmore 94223 Electric Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
124 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
