Question about Whirlpool LSQ8543J
Washer Won't Agitate
I have a Whirlpool Ultimate Care II Model: LSQ8543JQ1, Serial: CL 0718595 Type: 111 and just within the last couple weeks it won't agitate unless you grab it at the top and help it. Then it stops again and shakes. What do you suggest to correct the problem? Thanks in advance, How do i take the back of the wahser off and replace my water pump
  • 537 Answers
It might be the agitator dogs. Try to replace those
Posted on Feb 06, 2009
I have an whirlpool ultimate care II Imperial Series Model # LSN2000JQ2 Serial:CM2819491 Type: III That will fill but won't agitate. Is this something I can really fix on my own?
Could be a problem with the lid switch or motor coupling. Does it drain? Does it spin?
when its time to agitate or spin, do you hear the motor?
Lets start with the lid switch. open the lid and use a screw driver to push the switch down. pay attention to see if you hear it click. Try to run the unit with the screw driver holding down the switch.
Let me know what happens so I can further assist you.
Feb 20, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool Ultimate Care II LSQ9665JQ0. Just replaced motor coupling a week ago. Now the washer will not agitate on extra delicate cycle or hand washable cycle. Works fine on Normal and...
When you replaced the motor coupler, did you remove the wiring harness from the motor? If you did, then check to see if you bent a pin aside on the motor when you plugged it back in. I have done this numerous times myself.
Dec 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Wobbly agitator
If you remove the center cap from the agitator there should be either a bolt or a square recessed socket that you can attempt to tighten. The bolt is either 7/16" or 1/2". The recessed socket can be tightened using a 3/8" to 1/2" socket adapter.
Make sure the agitator is seated properly on the center post. You can accomplish this by finding the mounting bolt and loosening it enough to free the agitator on the post and push down evenly on the bottom flanges at the base of the agitator where it meets to bottom of the tub.
Try this and let me know if it helps. Post back if you need further assistance.
Feb 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Won't Work
I not sure but sounds like u have a 2 piece agitator... sounds like gears in top of agitator is stripped.. you can replace them for few bucks ... if its a 2 piece agi.
Sep 07, 2007 | Washing Machines
I would make sure that the washer is properly leveled, and ensure that all sensors that check if the door is closed are working properly.
Sep 07, 2007 | Estate TAWB600JQ Top Load Washer
Washing Machines Logo
307 people viewed this question
Dan Webster
Dan Webster
Sal De
