Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Feb 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C0000221 Unknown Hard Error\System32\ntdll.dll
Still have problem.... error on
"C0000221 Unknown Hard Error\System32\ntdll.dll"
what should i do? by the way im using xp
Mike McWhinney
Level 3:
  • Master 537 Answers
  • Posted on Feb 06, 2009
Mike McWhinney
Master
Level 3:
Answers
537
Questions
9
Helped
328975
Points
1551
From MS's KB:
http://support.microsoft.com/kb/314474
No sound no audiono ethernet hard error c0000221
Here is an explanation of your problem - http://support.microsoft.com/default...;en-us;Q314474
and ways of fixing it. Regards.
Download the file here http://www.dlldump.com/download-dll-.../download.html and replace the corrupted file .. it should be in C:\Windows\system32
When you boot up, go into Safe Mode (tap the f8 key as its starting to boot up and select Safe mode from the resulting menu). Now go to the 'problem' dll, right click on it and select rename. Rename it to ntdll.dll.old then paste the new .dll into the system32 file
Hope this helps
2helpful
"stop c0000221 unknown hard error
If you are getting this error when trying to reinstall from your XP cd, then it sounds like you have a loose damaged or incorrect cable to either your cdrom or hard drive. I suggest replacing them both with quality 80 wire 40 pin IDE cables. It can also be caused by incorrect configuration if you have RAID or SATA drives.
Finally you may want to try with just one stick of RAM installed. If you have more than one now; you should try each in the slot nearest the processor all by itself until you rule out one of them being bad (If it works with one stick and not the other, you know the other is bad).
There is more information on possible causes of this error at ahuma ; but my first suspicion on seeing the image checksum mismatch is that the file in question has been replaced with something else, a trojan or virus.
Please download
Mcafee stinger multivirus removal tool
Install and run
Thanks
Arnob
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
2answers
When i start my computer i get this message: stop: c0000221 UNKNOWN HARD ERROR /SYSTEMROOT/SYSTEM32/NTDLL.DLL what can i do?
I have a wipro laptop. i install windows Xp .But my system could show the operating system error . Then I am reinstalled Windows Xp. But the system will turnoff.
1helpful
2answers
Stop:c0000221 unknown hard error\systemRoot\System32\ntdll.dll I get this error message when installing a brand new hard drive onto a Dell d610 laptop. This message appears when setup is starting windows
Hello cluikart,
Here are a couple of links that might give you an idea about the windows stop error. I hope the information on these sites can help you resolve the problem:
1). Annoyances.org: http://www.annoyances.org/exec/forum/winxp/t1030972927
2). Microsoft Support: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314474
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
1helpful
2answers
Hard error : STOP C000021
This is a common error
just copy or download ntdll.dll file from the net and replace the file in ur disc
then just make a new bootable iso file and burn into a new cd
restart the comp,install and enjoy
Shreyas
Cheers
1helpful
Unknown Hard Error
It's probably a corrupted file on the hard drive due a variety of reasons. A simple defrag might fix it but it's unlikely, so it is probably preferable to a Repair function from your XP install CD. These kinds of errors with XP were not uncommon. After the Repair assuming it works and I'm fairly certain that it will, defrag your hard drive and then start getting the new updates for your system.
Illustrated procedures located here
Windows xp installation
HI,
Here is what the Media test failure check cable eiting PXE ROM means:
Iam sure when we were changing some settings with the BIOS you must have done something wrong.Just reemember if you changed some settings over there.
try change the boot-order in the BIOS
try to disable "network-boot" in the BIOS.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive. To resolve this issue,Isuggest you go through the steps in document CH000229 relating to a similar error message.
Now coming to System32\ntall.dll unknown hard error:
Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
If the ntdll.dll error only displays when you use a specific software program, uninstall the program, reboot your computer, and then install the latest version again from scratch.
Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Perform a repair installation of Windows XP. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file. Remember to install all Windows service packs and other patches after this installation.
Perform a clean installation of Windows XP. A clean installation will completely remove Windows XP from your PC and install it again from scratch. I don't recommend this step unless you have stepped through all previous troubleshooting steps and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2). NOTE:a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive. If so, replace the hard drive and then perform a new installation of Windows XP.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
