Question about Onkyo TX-SR606 Receiver
Rained on my new Onkyo - it wasn't plugged in tho!
Hi all. I had my new receiver sitting unplugged on a shelf waiting to set it up this weekend. We had an unexpected early rain, my windows were open, and I came home to find that rain had gotten all over the top of the unit.
I freaked out because it was after 5p (otherwise I would have taken it straight to a repair shop). I wiped off the top with a towel. Then I gently turned the unit upside down on another dry towel and let it sit for 30 minutes so it could drain out any rain that seeped inside.
I didn't want to let anything corrode, so I now have a hair dryer suspended about 4 feet above the unit blowing warm (not hot) air into the vents.
What should I do next? If I continue to "dry out" the unit w/the blow dryer, will it be ok, or should I still take it to a repair facility?
I'm bummed because I just bought it and haven't even taken the labels off yet!
Thanks in advance!!!
  • 27 Answers
No need for a repair shop. Just open the top (two big screws on each side and a few smaller ones in the back) Let it sit for another day that way and it'll be right as rain. Oops...poor choice of words.
Avoid the urge to touch the circuit boards on the inside. Static electricity could damage the circuits. Instead, put it next to a fan - or in a room with a ceiling fan.
When you're don, plug it in and enjoy your new stereo.
Peace.
Marco
Posted on Feb 06, 2009
How do I troubleshoot my Onkyo AV Receiver TX-SR603?
Based on your account it appears that you may have an issue with the power supply of the receiver.
Jun 13, 2016 | Onkyo Audio Players & Recorders
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Have Onkyo TX-NR808 receiver. Not quite 3 months old. Unit shut down when volume was turned up, but not drastic. Tried to adjust the db levels of my front speakers, in particular the center channel. As I...
The problem is the audio output ic's, one or more channels has developed a short causing the safety shutdown to engage. The only solution is take it back where it was purchased and since it is under warranty it should be repaired free of charge if not a possible exchange.
Jan 09, 2011 | Onkyo TXNR808 Receiver
I have the TX SR706 receiver for two years and yesterday when I turn it on it did a load boom sound and since then there are no sound
I had this happen to my unit shortly after I purchased it. When I turned the receiver on there was a loud pop through the speakers, the red light on the front started blinking and the unit failed to produce sound.
A tack worked its way through one of the speaker wires, causing a short. I replaced the wire and unplugged the receiver for an hour. It's worked well for the past two years since this issue.
If you haven't done so already, check all of your speaker wires and plugs on the receiver and the speakers. You may have a damaged wire or metal-on-metal contact somewhere. Try these steps:
1. Unplug the unit and disconnect all wires and connections. Let the unit sit for an hour.
2. Check all cords for damage or crossed connections.
3. Reconnect the power cord and set the volume to minimum. Turn the receiver on. If it stays on, shut it off, unplug it and reconnect everything, taking care to ensure that speaker wires and/or plugs don't make contact.
4. Plug the receiver in, set the volume to minimum (it should already have this setting after step 3) and turn it on.
It sounds like there is a short somewhere in either the wiring or the receiver. This caused the popping noise and activated the receiver's protection circuit. If it's a damaged wire or plugs or wires making contact, you can reset the unit with the directions above, replace or separate the wires and all should work. If the issue is within the unit, you'll have to contact Onkyo directly.
Dec 11, 2010 | Onkyo TX-SR706 Receiver
Unable to use sumsung receiver /disc amplifier
Contact Onkyo website - usually a malfunction in the unit requiring service, and you cannot reset it. HOWEVER, try the usual unplug, wait and plug-in again. Make sure that there's not a shorted speaker - so unplug all speakers and try using just headphones. Also, make sure you have air ventilation around the unit - nothing on top of it, as that will cause it to overhead and shutdown. Try these items and report back. Good Luck!
Dec 29, 2009 | Onkyo TX-DS787 Receiver
Onkyo Rec(R-805X)does not work-constant clicking when plugged in
i have a similar problem, i plug it in and let it click to its hearts content, it will speed up to a very fast rate then slow down and eventually stop... then the unit will work fine for a couple of days but the clicking will return its not a permanent solution but it works
Dec 04, 2009 | Onkyo Audio Players & Recorders
My Onkyo TX-SR606 will not turn off, will not adjust volume, will not change modes, will not do anything but stay "stuck" on cable/satellite at volume 33. It will not reset. I unplugged it, waited, and...
contact onkyo and ask for a disc that you use threw the cd player via a toslink . The disc will upgrade your avr ,thus overwriting any problems you had. My tx-sr705 had an issue with popping during blu ray playback while the dts-master audio was being used. I got a disc that upgraded the chip that utilizes the codec's.
Aug 14, 2009 | Onkyo TX-SR606 Receiver
ONKYO MC35TECH aka R-805X
Hi if you need a replacement plug for the system then you can buy them from any electrical store but if you want a transformer or anything product specific then you can contact Onkyo USA sevice centre on 201-785-2600.
Here is the Onkyo website where the number is from
. http://www.onkyousa.com/customer_support.cfm
Or for European service centres go here: http://www.eu.onkyo.com/indices/index_com_en_2008_5946251.html
Oct 29, 2008 | Onkyo MC35Tech CD Shelf System
Onkyo receiver problems
All speakers and lines OK?  Sorry for basic approach!!  Protection is supposed to work when speaker outputs are loaded under recommended Z. speaker Z is a setting too ... along with several other paramenters.  Also, re the "last return" ...  Maybe the back surround speakers were turned off in settings?  Again, apologies if you've tried all this basic stuff.  I've just bought one of these amps and have probs with the FM tuner not tuning anything.  Mmmm. Back to the shop??   Cheers, Chris
Oct 03, 2007 | Onkyo TX-SR503 Receiver
Onkyo TX-SR504 - Sound problem
Ooops, that did not work.  OK try  http://www.retrevo.com/s/Onkyo-TX-SR503-Receivers-review-manual/id/365ag216/t/1-2/  for download of manual in .pdf form, and English too!   Hope this helps.  Cheers,   Chris  :)
May 05, 2007 | Onkyo TX-SR503 Receiver
Onkyo TX-SR606 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
